DES-N1916 The Ins and Outs of I2C Bus Buffers
The I2C bus has expanded from its humble beginnings in 1980s home electronics to both small and large scale systems in the modern world. Applications range from Smartphones to Server farms, and while they're true to the original simple signaling protocol other I2C bus components are needed to expand, adapt or buffer those signals. We take an in depth technical look at the simple Bus Buffer. Often needed, and seldom understood.
添付
評価なし
バージョン履歴
最終更新日:
‎05-25-2016 09:28 AM
更新者:
