mcu-s32k144(s32design studio version2.2) data lost from generated flash image file of srec-format
1,684 次查看
zhou_2020
Dear madam or sir:
I have created a new software project in s32design studio  version 2.2, using s32k144-mcu without sdk.  output flash image  is configured as motorola's  srec format.
  I encountered a question about the .ld file and  it generated data。
 The default flash memory is composed of  m_interrupts,m_flash_config and text.
but the m_interrupts and m_flash_config  zone were  lost  in  project's output srec file (pictures shows as below).
But when i build the older version  software project which downloaded  from NXP.com,this problem disappeared。
1,678 次查看
danielmartynek
Can you attach the project?
When I create a new project in S32DS 2.2 and select Create flash image, the generated srec file is correct.
