S32K144 FTM/PWM + DMA output one more unneeded Pulse
JianqiangSun
I referenced Example_S32k118_FTM_PWM_DMA_SDK303, and implemented the RZ code generation with circular DMA.
The problem is:
    a redundant 1-code being sent when the first duty-cycle is for 1-code.
How could this happen and how to fix it?
Tags (4)
JianqiangSun
Comment: used: SDK3.0, S32 Design Studio for ARM 2.2
Thanks a lot.
