I built android automotive os for arm machine . Now I want to run those emulator image on i.mx8. is it possible or any other way ??
guruvendrachowd
I built emulator images for x86 and arm machine to run android automotive os. Now I want build images for imx8mqevk for same android automotive os.
Is there any possibility that arm based emulator images can flash into imx8mqevk board ??
Please provide solution
Thanks and regards
Guru
gusarambula
Hello Guru,
Would you please give us more details on what your setup is? You want to run an emulator on the i.MX8?
