FAQ based on S32G HSE-H
Some common issues of HSE-H based on S32G are summarized. Hope it can help you understand the known issues of HSE-H.
The issue contents have been listed to facilitate finding the topic you care about. Please refer to the attachment for details. Thank you.
HSE FW Attributes
  • Q: When is power on VDD_EUFSE required ?
  • Q: Why does the HSE self-test fail in HSE FW 1.0.5
  • Q: How to sign for serial bootloader
  • Q: Which data of SYS_IMG will be verified during boot phase
  • Q: What is SIMULATED_OEM/IN_FEILD attribute and how to use it?
  • Q: Where can I check the anti-rollback counter numbers in FW_IMG* and SYS_IMG?
  • Q: How does HSE allocate time slots if there are multiple service requests?
  • Q: What are heavy operations and what are fast operations?
  • Q: What to do if a fatal error occurs (GSR bit 16 to bit 31 non-zero)?
  • Q: What do those fatal errors in GSR stand for?
  • Q: Can we verify the Blue image offline?
  • Q: Is anti-rollback protection enabled by default?
  • Q: What is random IV number
  • Q: Is it feasible to format the key catalog in SYS_IMG when LC=IN_FEILD?
  • Q: Does FSR and GSR have same value for each MUs?
Boot
  • Q: Boot flow
  • Q: Secure boot
  • Q: If IVT_AUTH==1, can BOOT_SEQ keep to non-secure boot(BOOT_SEQ==0)
  • Q: What may cause secure boot fail
HSE FW Service
  • Q: Why some services are taking longer times than usual
  • Q: How often is the RNG reseeded
  • Q: Which services may include RNG reseeding?
  • Q: Does HSE UIO support suspend&resume?
  • Q: How to export derive keys
  • Q: Which key usage flags have conflict
  • Q: How to import keys that crypto driver doesn’t support?
HSE FW Others
  • Q: How to power VDD_EFUSE
  • Q: Why should XRDC give HSE the access to  NCSPD_STAT register
  • Q: What should be done before Life_Cycle advancement?
  • Q: Why can't the 1.0.9 HSE demo load SYS_IMG with QSPI reconfiguration parameters when non-secure boot?
  • Q: Which peripherals’ access should be given to HSE in XRDC configuration?
  • Q: Why do we recommend switching HSE FW from pink to blue?
%3CLINGO-SUB%20id%3D%22lingo-sub-1983572%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EFAQ%20based%20on%20S32G%20HSE-H%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983572%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CDIV%20class%3D%22lia-message-template-question-zone%22%3E%0A%3CP%3ESome%20common%20issues%20of%20HSE-H%20based%20on%20S32G%20are%20summarized.%20Hope%20it%20can%20help%20you%20understand%20the%20known%20issues%20of%20HSE-H.%3C%2FP%3E%0A%3CP%3EThe%20issue%20contents%20have%20been%20listed%20to%20facilitate%20finding%20the%20topic%20you%20care%20about.%20Please%20refer%20to%20the%20attachment%20for%20details.%20Thank%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHSE%20FW%20Attributes%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EQ%3A%20When%20is%20power%20on%20VDD_EUFSE%20required%20%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Why%20does%20the%20HSE%20self-test%20fail%20in%20HSE%20FW%201.0.5%3C%2FLI%3E%0A%3CLI%3EQ%3A%20How%20to%20sign%20for%20serial%20bootloader%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Which%20data%20of%20SYS_IMG%20will%20be%20verified%20during%20boot%20phase%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20is%20SIMULATED_OEM%2FIN_FEILD%20attribute%20and%20how%20to%20use%20it%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Where%20can%20I%20check%20the%20anti-rollback%20counter%20numbers%20in%20FW_IMG*%20and%20SYS_IMG%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20How%20does%20HSE%20allocate%20time%20slots%20if%20there%20are%20multiple%20service%20requests%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20are%20heavy%20operations%20and%20what%20are%20fast%20operations%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20to%20do%20if%20a%20fatal%20error%20occurs%20(GSR%20bit%2016%20to%20bit%2031%20non-zero)%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20do%20those%20fatal%20errors%20in%20GSR%20stand%20for%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Can%20we%20verify%20the%20Blue%20image%20offline%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Is%20anti-rollback%20protection%20enabled%20by%20default%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20is%20random%20IV%20number%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Is%20it%20feasible%20to%20format%20the%20key%20catalog%20in%20SYS_IMG%20when%20LC%3DIN_FEILD%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Does%20FSR%20and%20GSR%20have%20same%20value%20for%20each%20MUs%3F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EBoot%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EQ%3A%20Boot%20flow%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Secure%20boot%3C%2FLI%3E%0A%3CLI%3EQ%3A%20If%20IVT_AUTH%3D%3D1%2C%20can%20BOOT_SEQ%20keep%20to%20non-secure%20boot(BOOT_SEQ%3D%3D0)%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20may%20cause%20secure%20boot%20fail%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EHSE%20FW%20Service%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EQ%3A%20Why%20some%20services%20are%20taking%20longer%20times%20than%20usual%3C%2FLI%3E%0A%3CLI%3EQ%3A%20How%20often%20is%20the%20RNG%20reseeded%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Which%20services%20may%20include%20RNG%20reseeding%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Does%20HSE%20UIO%20support%20suspend%26amp%3Bresume%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20How%20to%20export%20derive%20keys%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Which%20key%20usage%20flags%20have%20conflict%3C%2FLI%3E%0A%3CLI%3EQ%3A%20How%20to%20import%20keys%20that%20crypto%20driver%20doesn%E2%80%99t%20support%3F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EHSE%20FW%20Others%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EQ%3A%20How%20to%20power%20VDD_EFUSE%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Why%20should%20XRDC%20give%20HSE%20the%20access%20to%26nbsp%3B%20NCSPD_STAT%20register%3C%2FLI%3E%0A%3CLI%3EQ%3A%20What%20should%20be%20done%20before%20Life_Cycle%20advancement%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Why%20can't%20the%201.0.9%20HSE%20demo%20load%20SYS_IMG%20with%20QSPI%20reconfiguration%20parameters%20when%20non-secure%20boot%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Which%20peripherals%E2%80%99%20access%20should%20be%20given%20to%20HSE%20in%20XRDC%20configuration%3F%3C%2FLI%3E%0A%3CLI%3EQ%3A%20Why%20do%20we%20recommend%20switching%20HSE%20FW%20from%20pink%20to%20blue%3F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-template-answer-zone%22%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1983572%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ESome%20common%20issues%20of%20HSE-H%20based%20on%20S32G%20are%20summarized.%20Hope%20it%20can%20help%20you%20understand%20the%20known%20issues%20of%20HSE-H.%3C%2FP%3E%0A%3CP%3EThe%20issue%20contents%20have%20been%20listed%20to%20facilitate%20finding%20the%20topic%20you%20care%20about.%20Please%20refer%20to%20the%20attachment%20for%20details.%20Thank%20you.%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1983572%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomotive%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-06-2025 12:11 PM
Updated by:
