what is difference between NTA53321G0FHK and NTA53321G0FHKZ.
Guofred
our customer development department  wants to know what is difference between NTA53321G0FHK and NTA53321G0FHKZ.
i couldn't find the relate information, only find the  NTA53321G0FHK no longer Manufactured.
would you like kindly help to share, thanks.
NTA53321G0FHK    (without Z)
NTA53321G0FHKZ    (with Z)
Best regards.
Guofred
Fabian_R
Thank you for using our products, if you click on the BUY/PARAMETRICS tab, in the NTA53321G0FHK, you will see that there were two options under the Environmental section (NTA53321G0FHK(X) or NTA53321G0FHK(Z) they both share the type (NTA53321G0FHK) but the Z is now, our only orderable option. There isn't any difference between types.
As you know, the (X) type isn't longer manufactured.
Fabian
Fabian_R
Fabian
Guofred
Hi @Fabian_R ,
Ok, thanks for your kindly help.
Best regards.
Guofred
