Hello. I try to connect pn5180 to raspberry pi pico on rp2040 is it any schemes to connection and any library? I'll be very thankful! Thanks
Hi @chiffa ,
there is an application note in place to support that use-case: https://www.nxp.com/docs/en/application-note/AN11802.pdf
Even though a normal raspberry pi was used and not the pico variant. Please make sure to connect the right pins. Else I do not think there should be much of a difference.
Alexander
