ntp5312 read tag uid
VAZN
Hello everyone,
I want to use the NTP5312 to read/write nfc tags.
I have read the data-sheet but I don't find the way to do it. Should I use the SRAM and i2c to NFC pass-through to read and write nfc tags?
Thank you very much for your help
nxf58474
Hope you are doing well. Do you want to read/write on the NTAG5 or do you want to read/write other NFC tags with the NTP5312?
The NTAG 5 link is a NFC Tag, so you cannot use it to interact with other tags, you must have a NFC Reader to interact with the tags.
You can see our Recommended NFC Readers in this page: NFC Readers.
Ricardo
