nfc ntag215 remove password
ayyad
<div>
I send these raw commands:
AUTH TAG ( with default password )
nfc.transceive('1B FF FF FF FF')
CHANGE DEFAULT PASSWORD
nfc.transceive('A2 85 AA BB CC DD')
SET PACK
nfc.transceive('A2 86 EE FF 00 00')
PROTECT ADDRESS 04 TO 81
nfc.transceive('A2 84 80 00 00 00')
now how i can remove this password to back card can write ?
</div>
Fabian_R
Thank you for using our products.
To remove the password you need to authenticate and configure the respective page. Please take a look at section 8.8.1 Programming of PWD and PACK of the Datasheet.
Could you please clarify which reader are you using?
Fabian
ayyad
tag type : NXP -NTAG215
ayyad
Fabian_R
Hello sir my apologies but, I referred to the Reader you are using. As you can see in our portfolio: https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers:NFC-READER
There are several readers available, and some of them can be used with our NFC Reader Library. This library does include some functions to interface with NTAG 213 and, to correctly remove or modify the password once authenticated.
Fabian
ayyad
give me example for commands to set password 1234 and remove it for tag type 215
Fabian_R
Hello sir,
Unfortunately, I don't have an example for setting a password using an Android device. My recommendation would be to please take a look at the Datasheet commands, along with the NTAG 21x features and hints document.
We recommend to please take a look at our TapLinx SDK from Android which has a set of functions based on Android to read and write into tags.
Fabian
ayyad
I use NFC tools app
