ok, get it, but I hope get more infomation about random id, RID is enabled on SL3, I can't change SL3 to SL2 or lower level, but I think it can be enabled/disabled if it just a feature, I hava same issue on other NFC IC, can you give me some suggestion? thanks a lot
is there any ideas?
HI @jeremyliu
SN100T is not a mass market product. You need to contact with NXP local FAE or representative for support.
https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS
