gerber file for MFRC630
2,315 次查看
francescomariot
I would like to know if are available gerber and schematic files for  CLEV6630A(B) board or other boards with MFRC630 or CLRC663 IC. Many thanks
标记 (2)
3 回复数
2,017 次查看
kashyap_gada
Hi Estephania, The CLEV6630B Layout is in PDF Format. Where can we find/get it in gerber form altium/eagle?
For PN7462 Dev Kit Gerbers are available in proper format but for CLEV6630B its not the case.
Kashyap
2,110 次查看
francescomariot
Dear Estephania,
many thanks for your answer.
I have another question about layout for CLRC663 IC. I didn't understand, in the layer stackup, layer under the TOP (pag 2 of the document CLEV6630B_V2.0 PCB.pdf), this layer it seems to be filled only under loop antenna, can you give me more details about this?
Best Regards
Francesco
2,110 次查看
estephania_mart
By any chance does the CLRC663 plus CLRC6630B schematics and layout work for you?  Those files are available in the Software & Tools tab.
Estephania
