direct connection PN512 to tag pin
mohammad_arman
Hi.
I want to connect the pn512 TX1, TX2 outputs directly to the antenna pins of TAG chip. In this case, how is the matching circuit calculated?
fangfang
Hello @mohammad_arman .
Thanks for contacting NXP.
"pn512 TX1, TX2 outputs directly to the antenna pins of TAG chip"
In order to better service for you. Would you please describe your application?
Have a nice day.
mohammad_arman
@fangfang
thank you for your reply. I have some contactless MIFARE chips. I want to read and write data on them but due to limited space in my board, I can not use the antenna for them.
fangfang
Thanks for your update information.
Unfortunately. We have not the information for the application.
You may refer to the antenna videos as the below link.
https://www.nxp.com/video/nfc-antenna-design-1-which-antenna-for-what-purpose:WHICH-ANTENNA-PURPOSE-...
https://www.nxp.com/video/nfc-antenna-design-2-antenna-matching:ANTENNA-MATCHING-VIDEO
https://www.nxp.com/video/nfc-antenna-design-3-metal-environment:ANTENNA-METAL-ENVIRONMENT-VIDEO
https://www.nxp.com/video/nfc-antenna-design-4-optimization-debugging:ANTENNA-DEBUGGING-VIDEO
https://www.nxp.com/video/nfc-antenna-design-5-test-qualification:ANTENNA-TEST-QUALIFICATION-VIDEO
https://www.nxp.com/video/nfc-antenna-design-6-emc-related-design:ANTENNA-EMC-DESIGN-VIDEO
https://www.nxp.com/design/training/latest-nfc-antenna-design-hub:TIP-LATEST-NFC-ANTENNA-DESIGN
Have a nice day.
