Workaround for intermittent PN7150 reset after sending start discovery request?
1,638 次查看
anthony_asterisk
During operation I sometimes get a reset notification after sending a start discovery command.
The reset shows reason code is A3.  Before the reset an I2C request to start discovery had been sent.
[00:00:34.962,000] <info> nfc: NCI message rx'ed in state 11
[00:00:34.962,000] <info> nfc: 60 00 02 A3 00 |`....
1,534 次查看
anthony_asterisk
I am developing on a custom board developed with a Cortex-M4 processor.  The software is bare-metal, there is no software package.  Since the processor is also supporting several other peripherals a custom driver has been implemented that avoids blocking for long periods.  The provided example code does not appear to handle this error case.
1,534 次查看
IvanRuiz
Please accept my apologies. We recommend that you first start with our software and hardware before moving to a custom project.
Thank you for your comprehension.
Ivan.
1,533 次查看
IvanRuiz
Could you please provide us with the following information:
1. Are you working with the evaluation board?
2. Which host MCU are you working with?
3. Which software package?
Ivan.
