Which are the assembly parasitic parameters ( R and C) for the SL3S4011FHK chip
868 次查看
alexserres
I am developing a RFID tag antenna using the SL3S4011FHK, there is any information about the assembly parasitic parameters, only the Zchip = 12.7 +j199.
1 回复
758 次查看
vicentegomez
I do not know if you already check the application note AN11180
also please check the AN11215
I hope this will help you.
Vicente
