Vcc power on NT3H2111 (NTAG I2C Plus)
future_boston
For NT3H2111 (NTAG I2C Plus):
What is the maximum current on 3.3v Vcc during EEPROM write/erase? (when no RF field present)
What is the idle mode power consumption on Vcc?  (no I2C traffic)
future_boston
Data sheet has Idle State in section 8.2.2.1 and a Halt state in section 8.2.2.6.   These states have the same power consumption as the active state of 8.2.2.4 ?
weidong_sun
Hello Mike,
From datasheet: 240uA is max current for VCC, but if reading/esraing EEPROM, we should operate I2C bus, so current should be make up of 240uA & I2C bus(determined by the value of pull-up resistors)
The chip doesn't have idle mode.
Weidong
