Hello, I have a question. Can I use libnfc-nci to drive pn532? Do we have any instructions if it can be drived. I am looking forward to your feedback. Thank you!
Solved! Go to Solution.
Hi @rodger_an ,
theoratically yes. But you would have to implement some kind of translator as man-in-the-middle as the PN532 is not native NCI.
If you want to drive a NFC controller with the libnfc-nci I recommend to have a look at the PN7160. That should be kinda plug&play and exactly for that purpose.
Alexander
Hi @rodger_an ,
Alexander
Thanks for your reply. I will have a look into it.
