The data sheet described in the document was not found
3,094 次查看
tomhi
I want to know how to use DESFire command,  so I search related description in the MF3D(H)x2 product short data sheet(document number: 364231.https://www.nxp.com/docs/en/data-sheet/MF3DX2_MF3DHX2_SDS.pdf ).
In section 9 DESFire command set, it said: “This section contains an overview of MF3D(H)x2 command codes. A detailed description of all commands is provided in [1]”.
In section 11 References, it said: “[1] Data sheet MF3Dx2 MIFARE DESFire EV2 Functional specification, document number: 2260**”.
The problem is that I can't find this document on the official website.Where is this document? Thank u
2,650 次查看
Jonathan_Iglesias
Dear tom fan,
the information regarding the DESFire family, is secured under NDA (Non Disclosure Agreement) this means that all the information, support, etc. regarding this family should be done using secured communication channels and just to customer with active and signed NDA. as you can see the datasheet you are using is the short datasheet
if you want to have access to the full documentation please request an NDA in our private case system, the NDA team will help you sign this and guide you to the path to request the NDA documents.
Support|NXP
if you have any questions or issues please let me know.
Jonathan
2,651 次查看
Jonathan_Iglesias
Dear tom fan,
Support|NXP
Jonathan
