Save Settings in TagXplorer (with mirroring) for Batch Writing
jakefromoz
Hi, is there a way to save settings in TagXplorer so you can write the same data including mirroring settings to multiple tags? I.e. I want to write a URL + tag id + tag counter.
I know on the Android app there is a way to select an option 'Write multiple NFC tags one by one.' I want to do something similar with TagXplorer.
Or is there an better way to write data to many tags.
Thanks.
Kan_Li
I am sorry, but TagXplorer  doesn't support multiple tags operation, so you have to select tags one by one.
Sorry for the inconvenience that might cause.
Kan
jakefromoz
Hi Kan, is there other software that can handle multiple tags that you can recommend?
Kan_Li
Please refer to Activating multiple Tags using NFC Reader Library for details.
Kan
