SL3S4011 - How to write a bit in Configuration Word via I²C?
750件の閲覧回数
Lemer
hello,
I would like to write by I2C inside the configuration word. In the data sheet it is written that we can access with "standard READ / WRITE commands". I can read but he write does not change the content.
Do you have any suggestion or exemple?
I saw that there are already similar posts but always without a correct answer from the support...
0 返答(返信)
