PN7362 related questions
Karyliu
Hi NXP,
Can PN7362 USB CCID interface meet the following requirements?
1.Compotibility
    ·NFC forum certified
    ·J-LIS(Japan)compliant
     ·BSI(Germany)compliant
2.Support PC/SC(windows API, winscard.dll) and PC/SC Lite(Linux)
       ·Possible to work without a vendor SDK
3. certified as WHQL(Windows Hardware Quality Labs)
4.  support USB redirection under Citrix\VMWare
5.  support card emulation.
Looking forward to your reply, thank you.
KaiLi
Hello @Karyliu
Thanks for contacting us and interested in the NXP products.
Based on your description PN7362 does not meet your requirements what you mentioned, unfortunately.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002qYtj8AAC
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
