PN7220 Android support
1,434 次查看
qiuquanfeng
Hi, hope you have a good day.
I plan to use PN7220 as a pos payment application. Read the datasheet of NFC chip PN7220, the chip supports Android 13-14, I would like to ask whether it can support Android 12?
#PN722 #NFC
标记 (1)
1,416 次查看
KaiLi
Hello @qiuquanfeng
PN7220 support Android onwards 13, if you must start to Android 12 then recomended to switch PN7160.
1,417 次查看
KaiLi
Hello @qiuquanfeng
1,412 次查看
qiuquanfeng
Hi KellyLi
Thank you very much for your reply!
For POS terminal applications, must EMVCo standards be met? Do you have any other chips you recommend?
1,402 次查看
KaiLi
Hello @qiuquanfeng
PN5190 recommends to you, but it cannot be running on Android.
