PN7160 firmware update failed!
jiafangguo
Hello all,
Our board use OS:
root@qrb5165-rb5:~# uname -a
Linux qrb5165-rb5 4.19.125 #1 SMP PREEMPT Fri Aug 26 21:26:36 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
I am trying to port OM27160A1 to QCOM sm8250 linux board. For nfc lib: (./configure --enable-debug), run nefdemoapp poll got error:
root@qrb5165-rb5:~# nfcDemoApp poll
## NFC demo ##
## Poll mode activated ##
after init env
... press enter to quit ...
(cmd_poll)(1897)
(InitMode)(590)
2022:08:27-00:55:40.648 find found NXPLOG_NCIHAL_LOGLEVEL=(0x3)
2022:08:27-00:55:40.648 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIHAL_LOGLEVEL=(0x3)
2022:08:27-00:55:40.649 find found NXPLOG_EXTNS_LOGLEVEL=(0x3)
2022:08:27-00:55:40.649 GetNxpNumValue: NXP Config Parameter : NXPLOG_EXTNS_LOGLEVEL=(0x3)
2022:08:27-00:55:40.649 find found NXPLOG_TML_LOGLEVEL=(0x3)
2022:08:27-00:55:40.649 GetNxpNumValue: NXP Config Parameter : NXPLOG_TML_LOGLEVEL=(0x3)
2022:08:27-00:55:40.649 find found NXPLOG_FWDNLD_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 GetNxpNumValue: NXP Config Parameter : NXPLOG_FWDNLD_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 find found NXPLOG_NCIX_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIX_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 find found NXPLOG_NCIR_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIR_LOGLEVEL=(0x3)
2022:08:27-00:55:40.650 phNxpLog_InitializeLogLevel: global =3, Fwdnld =3, extns =3, hal =3, tml =3, ncir =3, ncix =3
(InitMode)(592)
(InitMode)(609)
(doInitialize)(188)
2022:08:27-00:55:40.651 loadConfig
2022:08:27-00:55:40.651 Entry
2022:08:27-00:55:40.651 getFilePath: enter FileType:0x02
2022:08:27-00:55:40.651 path:
2022:08:27-00:55:40.652 //usr/local//etc//libnfc-nci.conf
2022:08:27-00:55:40.652 ConfigFile - Parsing file '
2022:08:27-00:55:40.652 '
2022:08:27-00:55:40.653 ConfigFile - [
2022:08:27-00:55:40.653 APPL_TRACE_LEVEL
2022:08:27-00:55:40.653 ] =
2022:08:27-00:55:40.653 0xFF
2022:08:27-00:55:40.654 ConfigFile - [
2022:08:27-00:55:40.654 PROTOCOL_TRACE_LEVEL
2022:08:27-00:55:40.654 ] =
2022:08:27-00:55:40.654 0xFFFFFFFF
2022:08:27-00:55:40.655 NFC_DEBUG_ENABLED
2022:08:27-00:55:40.655 ] =
2022:08:27-00:55:40.655 0x01
2022:08:27-00:55:40.655 ConfigFile - [
2022:08:27-00:55:40.655 NFA_STORAGE
2022:08:27-00:55:40.656 ] =
2022:08:27-00:55:40.656 "/data/vendor/nfc"
2022:08:27-00:55:40.656 ConfigFile - [
2022:08:27-00:55:40.656 HOST_LISTEN_TECH_MASK
2022:08:27-00:55:40.657 0x07
2022:08:27-00:55:40.657 ConfigFile - [
2022:08:27-00:55:40.657 SCREEN_OFF_POWER_STATE
2022:08:27-00:55:40.657 ] =
2022:08:27-00:55:40.657 1
2022:08:27-00:55:40.658 ConfigFile - [
2022:08:27-00:55:40.658 NCI_HAL_MODULE
2022:08:27-00:55:40.658 ] =
2022:08:27-00:55:40.658 "nfc_nci.pn54x"
2022:08:27-00:55:40.658 POLLING_TECH_MASK
2022:08:27-00:55:40.659 ] =
2022:08:27-00:55:40.659 0xCF
2022:08:27-00:55:40.659 ConfigFile - [
2022:08:27-00:55:40.660 P2P_LISTEN_TECH_MASK
2022:08:27-00:55:40.660 ] =
2022:08:27-00:55:40.660 0xC5
2022:08:27-00:55:40.660 ConfigFile - [
2022:08:27-00:55:40.660 PRESERVE_STORAGE
2022:08:27-00:55:40.660 0x01
2022:08:27-00:55:40.661 ConfigFile - [
2022:08:27-00:55:40.661 AID_MATCHING_MODE
2022:08:27-00:55:40.661 ] =
2022:08:27-00:55:40.661 0x03
2022:08:27-00:55:40.661 NFA_MAX_EE_SUPPORTED
2022:08:27-00:55:40.661 0x01
2022:08:27-00:55:40.661 OFFHOST_AID_ROUTE_PWR_STATE
2022:08:27-00:55:40.661 0x3B
05:FF:FF:06:81:80:70:FF:FF
2022:08:27-00:55:40.662 ConfigFile - [
2022:08:27-00:55:40.662 NFA_PROPRIETARY_CFG
2022:08:27-00:55:40.662 ] =
2022:08:27-00:55:40.662 {05:FF:FF:06:81:80:70:FF:FF}
2022:08:27-00:55:40.662 initializeGlobalDebugEnabledFlag: level=1
2022:08:27-00:55:41.004 initializeGlobalDebugEnabledFlag: level=1
2022:08:27-00:55:41.005 readConfig Opened base config /usr/local/etc/libnfc-nci.conf
2022:08:27-00:55:41.008 NfcAdaptation::Initialize: Overriding NFA_EE_MAX_EE_SUPPORTED to use 1
2022:08:27-00:55:41.009 verify_stack_non_volatile_store
2022:08:27-00:55:41.010 crcChecksumVerifyIntegrity: filename=/nfaStorage.bin1
2022:08:27-00:55:41.010 crcChecksumVerifyIntegrity: filename=/nfaStorage.bin4
2022:08:27-00:55:41.011 crcChecksumVerifyIntegrity: filename=/nfaStorage.bin2
2022:08:27-00:55:41.012 crcChecksumVerifyIntegrity: filename=/nfaStorage.bin3
2022:08:27-00:55:41.013 crcChecksumVerifyIntegrity: filename=/nfaStorage.bin5
2022:08:27-00:55:41.014 Initialize: preserve stack NV store
2022:08:27-00:55:41.022 GKI_create_task func=0x0x7f944121b0 id=4 name=NFCA_TASK stack=0x(nil) stackSize=0
2022:08:27-00:55:41.023 GKI creating task 4, pCond/pMutex=(nil)/(nil)
2022:08:27-00:55:41.024 Leaving GKI_create_task 0x7f944121b0 4 7f936751d0 NFCA_TASK (nil) 0
2022:08:27-00:55:41.024 GKI_create_task func=0x0x7f9441237c id=0 name=NFCA_THREAD stack=0x(nil) stackSize=0
2022:08:27-00:55:41.025 GKI creating task 0, pCond/pMutex=(nil)/(nil)
2022:08:27-00:55:41.025 gki_task_entry task_id=4, thread_id=7f936751d0/7f936751d0, pCond/pMutex=(nil)/(nil)
2022:08:27-00:55:41.026 NfcAdaptation::NFCA_TASK: enter
2022:08:27-00:55:41.026 gki_task_entry task_id=0, thread_id=7f92e741d0/7f92e741d0, pCond/pMutex=(nil)/(nil)
2022:08:27-00:55:41.026 NfcAdaptation::Thread: enter
2022:08:27-00:55:41.027 GKI_create_task func=0x0x7f943b43e4 id=3 name=NFC_TASK stack=0x(nil) stackSize=0
2022:08:27-00:55:41.027 GKI creating task 3, pCond/pMutex=0x7f92e738f8/0x7f92e738c8
2022:08:27-00:55:41.028 GKI_run enter
2022:08:27-00:55:41.028 Start/Stop GKI_timer_update_registered!
2022:08:27-00:55:41.029 GKI_run, run_cond(0x7f9451d898)=1
2022:08:27-00:55:41.029 Leaving GKI_create_task 0x7f943b43e4 3 7f926731d0 NFC_TASK (nil) 0
2022:08:27-00:55:41.029 gki_task_entry task_id=3, thread_id=7f926731d0/7f926731d0, pCond/pMutex=0x7f92e738f8/0x7f92e738c8
2022:08:27-00:55:41.030 Leaving GKI_create_task 0x7f9441237c 0 7f92e741d0 NFCA_THREAD (nil) 0
2022:08:27-00:55:41.031 NFC_TASK started.
2022:08:27-00:55:41.031 GKI_wait task=3, pCond/pMutex = 0x7f92e738f8/0x7f92e738c8
2022:08:27-00:55:41.032 GKI_exit_task 0 done
2022:08:27-00:55:41.032 NfcAdaptation::Thread: exit
2022:08:27-00:55:41.032 gki_task task_id=0 terminating
2022:08:27-00:55:41.033 NfcAdaptation::Initialize: exit
2022:08:27-00:55:41.033 NFA_Init
2022:08:27-00:55:41.033 nfa_dm_init
2022:08:27-00:55:41.034 id=1, enable_cplt_mask=0x0
2022:08:27-00:55:41.034 nfa_p2p_init
2022:08:27-00:55:41.034 id=3, enable_cplt_mask=0x8
2022:08:27-00:55:41.035 Nfc: nfa_snep_init (): is_dta_mode=0
2022:08:27-00:55:41.035 Nfc: nfa_snep_default_init ()
2022:08:27-00:55:41.035 id=4, enable_cplt_mask=0x18
2022:08:27-00:55:41.036 nfa_rw_init
2022:08:27-00:55:41.036 id=5, enable_cplt_mask=0x38
2022:08:27-00:55:41.036 nfa_ce_init
2022:08:27-00:55:41.037 id=6, enable_cplt_mask=0x78
2022:08:27-00:55:41.037 nfa_ee_init
2022:08:27-00:55:41.037 id=2, enable_cplt_mask=0x7c
2022:08:27-00:55:41.038 nfa_t4tnfcee_init
2022:08:27-00:55:41.038 find found NXP_T4T_NFCEE_ENABLE=(0x1)
2022:08:27-00:55:41.039 GetNxpNumValue: NXP Config Parameter : NXP_T4T_NFCEE_ENABLE=(0x1)
2022:08:27-00:55:41.039 id=9, enable_cplt_mask=0x27c
2022:08:27-00:55:41.039 llcp_init
2022:08:27-00:55:41.040 num_rx_buff = 9, rx_congest_start = 6, rx_congest_end = 4, max_num_ll_rx_buff = 2
2022:08:27-00:55:41.040 max_num_tx_buff = 21, max_num_ll_tx_buff = 6
2022:08:27-00:55:41.040 SAP:0x1, link_type:0x2, ServiceName:<urn:nfc:sn:sdp>
2022:08:27-00:55:41.041 Registered SAP = 0x01
2022:08:27-00:55:41.041 NFA_Enable
2022:08:27-00:55:41.042 NFA got event 0x0100
2022:08:27-00:55:41.042 event: NFA_DM_API_ENABLE_EVT (0x00)
2022:08:27-00:55:41.042 nfa_dm_enable
2022:08:27-00:55:41.043 NFC_Enable
2022:08:27-00:55:41.043 nfc_set_state 0 (NONE)->1 (W4_HAL_OPEN)
2022:08:27-00:55:41.043 NfcAdaptation::HalOpen
2022:08:27-00:55:41.044 phNxpNci_MinOpen(): enter
2022:08:27-00:55:41.047 find found NXPLOG_NCIHAL_LOGLEVEL=(0x3)
2022:08:27-00:55:41.389 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIHAL_LOGLEVEL=(0x3)
2022:08:27-00:55:41.390 find found NXPLOG_EXTNS_LOGLEVEL=(0x3)
2022:08:27-00:55:41.390 GetNxpNumValue: NXP Config Parameter : NXPLOG_EXTNS_LOGLEVEL=(0x3)
2022:08:27-00:55:41.391 find found NXPLOG_TML_LOGLEVEL=(0x3)
2022:08:27-00:55:41.392 GetNxpNumValue: NXP Config Parameter : NXPLOG_TML_LOGLEVEL=(0x3)
2022:08:27-00:55:41.392 find found NXPLOG_FWDNLD_LOGLEVEL=(0x3)
2022:08:27-00:55:41.393 GetNxpNumValue: NXP Config Parameter : NXPLOG_FWDNLD_LOGLEVEL=(0x3)
2022:08:27-00:55:41.393 find found NXPLOG_NCIX_LOGLEVEL=(0x3)
2022:08:27-00:55:41.394 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIX_LOGLEVEL=(0x3)
2022:08:27-00:55:41.394 find found NXPLOG_NCIR_LOGLEVEL=(0x3)
2022:08:27-00:55:41.395 GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIR_LOGLEVEL=(0x3)
2022:08:27-00:55:41.396 phNxpLog_InitializeLogLevel: global =3, Fwdnld =3, extns =3, hal =3, tml =3, ncir =3, ncix =3
2022:08:27-00:55:41.396 find found MIFARE_READER_ENABLE=(0x1)
2022:08:27-00:55:41.397 GetNxpNumValue: NXP Config Parameter : MIFARE_READER_ENABLE=(0x1)
2022:08:27-00:55:41.399 Entering phNxpNciHal_init_monitor
2022:08:27-00:55:41.400 Returning with SUCCESS
2022:08:27-00:55:41.400 find found NXP_NFC_DEV_NODE
2022:08:27-00:55:41.400 GetNxpStrValue: NXP Config Parameter : NXP_NFC_DEV_NODE
2022:08:27-00:55:41.401 phTmlNfc_Init Entry......
2022:08:27-00:55:41.401 find found NXP_TRANSPORT=(0x0)
2022:08:27-00:55:41.401 GetNxpNumValue: NXP Config Parameter : NXP_TRANSPORT=(0x0)
2022:08:27-00:55:41.402 getTransport Requested transportType: 0
2022:08:27-00:55:41.402 OpenAndConfigure Opening port=/dev/nxpnfc
2022:08:27-00:55:41.413 NfccReset, VEN eType 0
2022:08:27-00:55:41.444 NfccReset, VEN eType 1
2022:08:27-00:55:41.466 PN54X - Tml Reader Thread Started................
2022:08:27-00:55:41.467 PN54X - Tml Writer Thread Started................
2022:08:27-00:55:41.468 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.469 phTmlNfc_Init exit wInitStatus=0
2022:08:27-00:55:41.470 thread started
2022:08:27-00:55:41.471 PN54X - Read requested.....
2022:08:27-00:55:41.472 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.472 PN54X - Write requested.....
2022:08:27-00:55:41.473 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.475 len = 4 > 20000100
2022:08:27-00:55:41.476 PN54X - I2C Write successful.....
2022:08:27-00:55:41.476 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:41.476 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.477 write successful status = 0x0
2022:08:27-00:55:41.477 Response timer started
2022:08:27-00:55:41.478 Waiting after ext cmd sent
2022:08:27-00:55:41.479 PN54X - I2C Read successful.....
2022:08:27-00:55:41.479 len = 4 > 40000100
2022:08:27-00:55:41.480 PN54X - Posting read message.....
2022:08:27-00:55:41.480 read successful status = 0x0
2022:08:27-00:55:41.481 CORE_RESET_RSP NCI2.0
2022:08:27-00:55:41.481 Response timer stopped
2022:08:27-00:55:41.482 Response timer started
2022:08:27-00:55:41.482 PN54X - Read requested.....
2022:08:27-00:55:41.483 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.485 PN54X - I2C Read successful.....
2022:08:27-00:55:41.486 len = 12 > 600009020020040471125005
2022:08:27-00:55:41.486 PN54X - Posting read message.....
2022:08:27-00:55:41.487 read successful status = 0x0
2022:08:27-00:55:41.487 CORE_RESET_NTF NCI2.0 reason CORE_RESET_CMD received !
2022:08:27-00:55:41.488 nci_version : 0x20
2022:08:27-00:55:41.488 getChipType HwVersion : 0x71
2022:08:27-00:55:41.489 getChipType Product : PN557
2022:08:27-00:55:41.489 phNxpNciHal_configFeatureList chipType = 9
2022:08:27-00:55:41.489 NxpNci> FW Version: 12.50.5
2022:08:27-00:55:41.490 Response timer stopped
2022:08:27-00:55:41.490 Checking response
2022:08:27-00:55:41.491 PN54X - Read requested.....
2022:08:27-00:55:41.492 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.492 PN54X - Write requested.....
2022:08:27-00:55:41.493 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.494 len = 5 > 2001020000
2022:08:27-00:55:41.495 PN54X - I2C Write successful.....
2022:08:27-00:55:41.495 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:41.496 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.496 write successful status = 0x0
2022:08:27-00:55:41.497 Response timer started
2022:08:27-00:55:41.497 Waiting after ext cmd sent
2022:08:27-00:55:41.498 PN54X - I2C Read successful.....
2022:08:27-00:55:41.499 len = 33 > 40011E001A7E060301D002FFFF01FF000800000100020003008000820083008400
2022:08:27-00:55:41.499 PN54X - Posting read message.....
2022:08:27-00:55:41.500 read successful status = 0x0
2022:08:27-00:55:41.500 CORE_INIT_RSP NCI2.0 received !
2022:08:27-00:55:41.501 Response timer stopped
2022:08:27-00:55:41.501 Checking response
2022:08:27-00:55:41.502 find found NXP_I2C_FRAGMENTATION_ENABLED=(0x0)
2022:08:27-00:55:41.845 GetNxpNumValue: NXP Config Parameter : NXP_I2C_FRAGMENTATION_ENABLED=(0x0)
2022:08:27-00:55:41.845 I2C status : 0
2022:08:27-00:55:41.846 PN54X - Read requested.....
2022:08:27-00:55:41.846 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.847 PN54X - Write requested.....
2022:08:27-00:55:41.848 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.850 len = 6 > 20030301A005
2022:08:27-00:55:41.851 PN54X - I2C Write successful.....
2022:08:27-00:55:41.852 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:41.852 PN54X - I2C Read successful.....
2022:08:27-00:55:41.853 len = 9 > 4003060001A0050110
2022:08:27-00:55:41.853 PN54X - Posting read message.....
2022:08:27-00:55:41.854 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.855 write successful status = 0x0
2022:08:27-00:55:41.855 read successful status = 0x0
2022:08:27-00:55:41.856 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-00:55:41.856 Response timer started
2022:08:27-00:55:41.857 Waiting after ext cmd sent
2022:08:27-00:55:41.857 Response timer stopped
2022:08:27-00:55:41.858 Checking response
2022:08:27-00:55:41.858 PN54X - Read requested.....
2022:08:27-00:55:41.859 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.859 PN54X - Write requested.....
2022:08:27-00:55:41.860 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.861 len = 8 > 20020501A0050100
2022:08:27-00:55:41.862 PN54X - I2C Write successful.....
2022:08:27-00:55:41.862 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:41.863 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.864 write successful status = 0x0
2022:08:27-00:55:41.864 Response timer started
2022:08:27-00:55:41.865 Waiting after ext cmd sent
2022:08:27-00:55:41.866 PN54X - I2C Read successful.....
2022:08:27-00:55:41.867 len = 5 > 4002020000
2022:08:27-00:55:41.867 PN54X - Posting read message.....
2022:08:27-00:55:41.868 read successful status = 0x0
2022:08:27-00:55:41.868 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-00:55:41.869 Response timer stopped
2022:08:27-00:55:41.869 Checking response
2022:08:27-00:55:41.870 PN54X - Read requested.....
2022:08:27-00:55:41.870 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.871 PN54X - Write requested.....
2022:08:27-00:55:41.871 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.873 len = 4 > 20000100
2022:08:27-00:55:41.873 PN54X - I2C Write successful.....
2022:08:27-00:55:41.874 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:41.874 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:41.874 write successful status = 0x0
2022:08:27-00:55:41.875 Response timer started
2022:08:27-00:55:41.876 Waiting after ext cmd sent
2022:08:27-00:55:41.877 PN54X - I2C Read successful.....
2022:08:27-00:55:41.877 len = 4 > 40000100
2022:08:27-00:55:41.877 PN54X - Posting read message.....
2022:08:27-00:55:41.878 read successful status = 0x0
2022:08:27-00:55:41.878 CORE_RESET_RSP NCI2.0
2022:08:27-00:55:41.879 Response timer stopped
2022:08:27-00:55:41.879 PN54X - Read requested.....
2022:08:27-00:55:41.880 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.880 Response timer started
2022:08:27-00:55:41.882 PN54X - I2C Read successful.....
2022:08:27-00:55:41.882 len = 12 > 600009020020040471125005
2022:08:27-00:55:41.882 PN54X - Posting read message.....
2022:08:27-00:55:41.883 read successful status = 0x0
2022:08:27-00:55:41.883 CORE_RESET_NTF NCI2.0 reason CORE_RESET_CMD received !
2022:08:27-00:55:41.883 nci_version : 0x20
2022:08:27-00:55:41.884 getChipType HwVersion : 0x71
2022:08:27-00:55:41.884 getChipType Product : PN557
2022:08:27-00:55:41.884 phNxpNciHal_configFeatureList chipType = 9
2022:08:27-00:55:41.884 NxpNci> FW Version: 12.50.5
2022:08:27-00:55:41.885 Response timer stopped
2022:08:27-00:55:41.885 Checking response
2022:08:27-00:55:41.885 PN54X - Read requested.....
2022:08:27-00:55:41.886 PN54X - Invoking I2C Read.....
2022:08:27-00:55:41.886 PN54X - Write requested.....
2022:08:27-00:55:41.886 PN54X - Invoking I2C Write.....
2022:08:27-00:55:41.887 len = 5 > 2001020000
2022:08:27-00:55:41.888 PN54X - I2C Write successful.....
2022:08:27-00:55:42.230 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:42.230 PN54X - I2C Read successful.....
2022:08:27-00:55:42.231 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:42.232 write successful status = 0x0
2022:08:27-00:55:42.232 len = 33 > 40011E001A7E060301D002FFFF01FF000800000100020003008000820083008400
2022:08:27-00:55:42.233 PN54X - Posting read message.....
2022:08:27-00:55:42.234 Response timer started
2022:08:27-00:55:42.234 Waiting after ext cmd sent
2022:08:27-00:55:42.235 read successful status = 0x0
2022:08:27-00:55:42.236 CORE_INIT_RSP NCI2.0 received !
2022:08:27-00:55:42.237 Response timer stopped
2022:08:27-00:55:42.237 Checking response
2022:08:27-00:55:42.238 Allocating Mem for Dnld Context..
2022:08:27-00:55:42.239 find found NXP_FW_TYPE=(0x1)
2022:08:27-00:55:42.240 GetNxpNumValue: NXP Config Parameter : NXP_FW_TYPE=(0x1)
2022:08:27-00:55:42.240 firmware type from conf file: 1
2022:08:27-00:55:42.241 PN54X - Read requested.....
2022:08:27-00:55:42.242 PN54X - Invoking I2C Read.....
2022:08:27-00:55:42.242 @@@//usr//local//lib//libpn7160_fw.so
2022:08:27-00:55:42.243 FW Image Length - ImageInfoLen 34542
2022:08:27-00:55:42.244 FW Image Info Pointer - pImageInfo 0x7f90e68018
2022:08:27-00:55:42.244 FW Major Version Num - 50
2022:08:27-00:55:42.245 FW Minor Version Num - 6
2022:08:27-00:55:42.245 FW Image Length - 34542
2022:08:27-00:55:42.246 FW Image Info Pointer - 0x7f90e68018
2022:08:27-00:55:42.246 FW version for FW file = 0x5006
2022:08:27-00:55:42.247 FW version from device = 0x125005
2022:08:27-00:55:42.248 PN54X - Write requested.....
2022:08:27-00:55:42.249 PN54X - Invoking I2C Write.....
2022:08:27-00:55:42.252 len = 6 > 20030301A008
2022:08:27-00:55:42.252 PN54X - I2C Write successful.....
2022:08:27-00:55:42.253 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:42.254 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:42.254 write successful status = 0x0
2022:08:27-00:55:42.255 PN54X - I2C Read successful.....
2022:08:27-00:55:42.256 len = 10 > 4003070001A008020000
2022:08:27-00:55:42.256 PN54X - Posting read message.....
2022:08:27-00:55:42.257 Response timer started
2022:08:27-00:55:42.258 Waiting after ext cmd sent
2022:08:27-00:55:42.259 read successful status = 0x0
2022:08:27-00:55:42.259 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-00:55:42.260 phNxpNciHal_print_res_status: Storing GPIO Values...
2022:08:27-00:55:42.260 Response timer stopped
2022:08:27-00:55:42.260 Checking response
2022:08:27-00:55:42.261 PN54X - Read requested.....
2022:08:27-00:55:42.261 PN54X - Invoking I2C Read.....
2022:08:27-00:55:42.261 PN54X - Write requested.....
2022:08:27-00:55:42.262 PN54X - Invoking I2C Write.....
2022:08:27-00:55:42.266 len = 39 > 20022401A014200000000000000000000000000000000000000000000000000000000000000000
2022:08:27-00:55:42.266 PN54X - I2C Write successful.....
2022:08:27-00:55:42.267 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:42.267 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:42.268 write successful status = 0x0
2022:08:27-00:55:42.268 PN54X - I2C Read successful.....
2022:08:27-00:55:42.268 len = 5 > 4002020000
2022:08:27-00:55:42.269 PN54X - Posting read message.....
2022:08:27-00:55:42.269 Response timer started
2022:08:27-00:55:42.269 Waiting after ext cmd sent
2022:08:27-00:55:42.269 read successful status = 0x0
2022:08:27-00:55:42.270 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-00:55:42.270 PN54X - Read requested.....
2022:08:27-00:55:42.270 PN54X - Invoking I2C Read.....
2022:08:27-00:55:42.271 Response timer stopped
2022:08:27-00:55:42.271 Checking response
2022:08:27-00:55:42.271 Starting FW update
2022:08:27-00:55:42.271 find found NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:42.272 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:42.272 find found NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:42.272 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:42.273 find found NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:42.614 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:42.614 gphNxpNciHal_fw_IoctlCtx.bClkSrcVal = 0x1
2022:08:27-00:55:42.615 gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x2
2022:08:27-00:55:42.615 gphNxpNciHal_fw_IoctlCtx.bTimeout = 0x6
2022:08:27-00:55:42.616 NfccReset, VEN eType 2
2022:08:27-00:55:42.748 Calling Seq handler for FW Download
2022:08:27-00:55:42.748 find found NXP_FW_TYPE=(0x1)
2022:08:27-00:55:42.749 GetNxpNumValue: NXP Config Parameter : NXP_FW_TYPE=(0x1)
2022:08:27-00:55:42.750 firmware type from conf file: 1
2022:08:27-00:55:42.751 free library SUCCESS !!
2022:08:27-00:55:42.753 @@@//usr//local//lib//libpn7160_fw.so
2022:08:27-00:55:42.753 FW Image Length - ImageInfoLen 34542
2022:08:27-00:55:42.754 FW Image Info Pointer - pImageInfo 0x7f90e68018
2022:08:27-00:55:42.754 FW Major Version Num - 50
2022:08:27-00:55:42.755 FW Minor Version Num - 6
2022:08:27-00:55:42.756 FW Image Length - 34542
2022:08:27-00:55:42.756 FW Image Info Pointer - 0x7f90e68018
2022:08:27-00:55:42.757 phDnldNfc_InitImgInfo:SUCCESS
2022:08:27-00:55:42.758 Processing Normal Sequence..
2022:08:27-00:55:42.758 Initializing Sequence..
2022:08:27-00:55:42.759 Response Timer Created Successfully
2022:08:27-00:55:42.760 Inserting FrameId ..
2022:08:27-00:55:42.760 Frame created successfully
2022:08:27-00:55:42.760 GetSessionState Request submitted successfully
2022:08:27-00:55:42.761 PN54X - Write requested.....
2022:08:27-00:55:42.761 PN54X - Invoking I2C Write.....
2022:08:27-00:55:42.764 len = 8 > 0004F2000000F533
2022:08:27-00:55:42.764 PN54X - I2C Write successful.....
2022:08:27-00:55:42.765 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:42.765 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:42.765 Send Success
2022:08:27-00:55:42.766 Response timer started
2022:08:27-00:55:42.766 PN54X - I2C Read successful.....
2022:08:27-00:55:42.767 len = 12 > 6008020500FFFFFFFFFFFFFF
2022:08:27-00:55:42.767 PN54X - Posting read message.....
2022:08:27-00:55:42.768 PN54X - Read requested.....
2022:08:27-00:55:42.768 PN54X - Invoking I2C Read.....
2022:08:27-00:55:42.769 Invalid frame received
2022:08:27-00:55:42.769 phNxpNciHal_fw_dnld_get_sessn_state_cb - Request Failed!!
2022:08:27-00:55:42.770 phDnldNfc_GetSessionState cb failed
2022:08:27-00:55:42.770 phNxpNciHal_fw_seq_handler : FAILED
2022:08:27-00:55:42.771 phNxpNciHal_fw_dnld_complete: Download Status = 0xff
2022:08:27-00:55:42.771 Fw Download Failed!!
2022:08:27-00:55:42.772 NfccReset, VEN eType 0
2022:08:27-00:55:42.803 NfccReset, VEN eType 1
2022:08:27-00:55:42.925 free library SUCCESS !!
2022:08:27-00:55:42.926 Freeing Mem for Dnld Context..
2022:08:27-00:55:42.926 Retrying: FW download
2022:08:27-00:55:42.927 find found NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:42.928 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:42.928 find found NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:42.929 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:42.930 find found NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:42.930 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:42.931 gphNxpNciHal_fw_IoctlCtx.bClkSrcVal = 0x1
2022:08:27-00:55:42.931 gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x2
2022:08:27-00:55:42.932 gphNxpNciHal_fw_IoctlCtx.bTimeout = 0x6
2022:08:27-00:55:42.932 NfccReset, VEN eType 2
2022:08:27-00:55:43.064 Allocating Mem for Dnld Context..
2022:08:27-00:55:43.065 Calling Seq handler for FW Download
2022:08:27-00:55:43.065 find found NXP_FW_TYPE=(0x1)
2022:08:27-00:55:43.066 GetNxpNumValue: NXP Config Parameter : NXP_FW_TYPE=(0x1)
2022:08:27-00:55:43.066 firmware type from conf file: 1
2022:08:27-00:55:43.068 @@@//usr//local//lib//libpn7160_fw.so
2022:08:27-00:55:43.069 FW Image Length - ImageInfoLen 34542
2022:08:27-00:55:43.069 FW Image Info Pointer - pImageInfo 0x7f90e68018
2022:08:27-00:55:43.070 FW Major Version Num - 50
2022:08:27-00:55:43.070 FW Minor Version Num - 6
2022:08:27-00:55:43.071 FW Image Length - 34542
2022:08:27-00:55:43.071 FW Image Info Pointer - 0x7f90e68018
2022:08:27-00:55:43.072 phDnldNfc_InitImgInfo:SUCCESS
2022:08:27-00:55:43.072 Processing Normal Sequence..
2022:08:27-00:55:43.073 Initializing Sequence..
2022:08:27-00:55:43.073 Response Timer Created Successfully
2022:08:27-00:55:43.074 Inserting FrameId ..
2022:08:27-00:55:43.074 Frame created successfully
2022:08:27-00:55:43.075 GetSessionState Request submitted successfully
2022:08:27-00:55:43.076 PN54X - Write requested.....
2022:08:27-00:55:43.076 PN54X - Invoking I2C Write.....
2022:08:27-00:55:43.079 len = 8 > 0004F2000000F533
2022:08:27-00:55:43.079 PN54X - I2C Write successful.....
2022:08:27-00:55:43.080 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:43.080 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:43.081 PN54X - I2C Read successful.....
2022:08:27-00:55:43.081 len = 12 > 6008020500FFFFFFFFFFFFFF
2022:08:27-00:55:43.082 PN54X - Posting read message.....
2022:08:27-00:55:43.083 Send Success
2022:08:27-00:55:43.083 Response timer started
2022:08:27-00:55:43.084 Invalid frame received
2022:08:27-00:55:43.084 PN54X - Read requested.....
2022:08:27-00:55:43.085 PN54X - Invoking I2C Read.....
2022:08:27-00:55:43.085 phNxpNciHal_fw_dnld_get_sessn_state_cb - Request Failed!!
2022:08:27-00:55:43.086 phDnldNfc_GetSessionState cb failed
2022:08:27-00:55:43.087 phNxpNciHal_fw_seq_handler : FAILED
2022:08:27-00:55:43.087 phNxpNciHal_fw_dnld_complete: Download Status = 0xff
2022:08:27-00:55:43.088 Fw Download Failed!!
2022:08:27-00:55:43.088 NfccReset, VEN eType 0
2022:08:27-00:55:43.120 NfccReset, VEN eType 1
2022:08:27-00:55:43.242 free library SUCCESS !!
2022:08:27-00:55:43.243 Freeing Mem for Dnld Context..
2022:08:27-00:55:43.244 Retrying: FW download
2022:08:27-00:55:43.244 find found NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:43.245 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_SRC_SEL=(0x1)
2022:08:27-00:55:43.246 find found NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:43.246 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_FREQ_SEL=(0x2)
2022:08:27-00:55:43.247 find found NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:43.247 GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLOCK_TO_CFG=(0x6)
2022:08:27-00:55:43.248 gphNxpNciHal_fw_IoctlCtx.bClkSrcVal = 0x1
2022:08:27-00:55:43.249 gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x2
2022:08:27-00:55:43.249 gphNxpNciHal_fw_IoctlCtx.bTimeout = 0x6
2022:08:27-00:55:43.250 NfccReset, VEN eType 2
2022:08:27-00:55:43.381 Allocating Mem for Dnld Context..
2022:08:27-00:55:43.382 Calling Seq handler for FW Download
2022:08:27-00:55:43.383 find found NXP_FW_TYPE=(0x1)
2022:08:27-00:55:43.383 GetNxpNumValue: NXP Config Parameter : NXP_FW_TYPE=(0x1)
2022:08:27-00:55:43.384 firmware type from conf file: 1
2022:08:27-00:55:43.386 @@@//usr//local//lib//libpn7160_fw.so
2022:08:27-00:55:43.386 FW Image Length - ImageInfoLen 34542
2022:08:27-00:55:43.387 FW Image Info Pointer - pImageInfo 0x7f90e68018
2022:08:27-00:55:43.388 FW Major Version Num - 50
2022:08:27-00:55:43.388 FW Minor Version Num - 6
2022:08:27-00:55:43.389 FW Image Length - 34542
2022:08:27-00:55:43.389 FW Image Info Pointer - 0x7f90e68018
2022:08:27-00:55:43.390 phDnldNfc_InitImgInfo:SUCCESS
2022:08:27-00:55:43.390 Processing Normal Sequence..
2022:08:27-00:55:43.391 Initializing Sequence..
2022:08:27-00:55:43.392 Response Timer Created Successfully
2022:08:27-00:55:43.392 Inserting FrameId ..
2022:08:27-00:55:43.393 Frame created successfully
2022:08:27-00:55:43.393 GetSessionState Request submitted successfully
2022:08:27-00:55:43.394 PN54X - Write requested.....
2022:08:27-00:55:43.394 PN54X - Invoking I2C Write.....
2022:08:27-00:55:43.398 len = 8 > 0004F2000000F533
2022:08:27-00:55:43.399 PN54X - I2C Write successful.....
2022:08:27-00:55:43.400 PN54X - Posting Fresh Write message.....
2022:08:27-00:55:43.400 PN54X - Tml Writer Thread Running................
2022:08:27-00:55:43.401 PN54X - I2C Read successful.....
2022:08:27-00:55:43.401 len = 12 > 6008020500FFFFFFFFFFFFFF
2022:08:27-00:55:43.402 PN54X - Posting read message.....
2022:08:27-00:55:43.402 Send Success
2022:08:27-00:55:43.403 Response timer started
2022:08:27-00:55:43.404 Invalid frame received
2022:08:27-00:55:43.404 PN54X - Read requested.....
2022:08:27-00:55:43.405 PN54X - Invoking I2C Read.....
2022:08:27-00:55:43.406 phNxpNciHal_fw_dnld_get_sessn_state_cb - Request Failed!!
2022:08:27-00:55:43.406 phDnldNfc_GetSessionState cb failed
2022:08:27-00:55:43.407 phNxpNciHal_fw_seq_handler : FAILED
2022:08:27-00:55:43.407 phNxpNciHal_fw_dnld_complete: Download Status = 0xff
2022:08:27-00:55:43.408 Fw Download Failed!!
2022:08:27-00:55:43.408 NfccReset, VEN eType 0
2022:08:27-00:55:43.440 NfccReset, VEN eType 1
2022:08:27-00:55:43.562 free library SUCCESS !!
2022:08:27-00:55:43.563 Freeing Mem for Dnld Context..
2022:08:27-00:55:43.564 Retrying: FW download
2022:08:27-00:55:43.564 Chip Version Middleware Version mismatch!!!!
2022:08:27-00:55:43.567 PN54X - Write request NOT enabled
jiafangguo
After changed my fw download gpio, device can download firmware, but still stuck when trying to poll:
sh-4.4# nfcDemoApp poll
## NFC demo ##
2022:08:27-02:13:36.316 NFA_StartRfDiscovery
2022:08:27-02:13:36.317 NFA got event 0x010E
2022:08:27-02:13:36.317 event: NFA_DM_API_START_RF_DISCOVERY_EVT (0x0e)
2022:08:27-02:13:36.317 nfa_dm_act_start_rf_discovery
2022:08:27-02:13:36.317 nfa_dm_start_rf_discover
2022:08:27-02:13:36.317 1
2022:08:27-02:13:36.318 0x0, 0x0, 0x0, 0x0
2022:08:27-02:13:36.318 nfa_dm_cb.disc_cb.entry[0].selected_disc_mask = 0x140000
2022:08:27-02:13:36.318 nfa_dm_cb.disc_cb.entry[1].selected_disc_mask = 0x6f7f
2022:08:27-02:13:36.318 nfa_p2p_set_config
2022:08:27-02:13:36.318 LLCP_GetDiscoveryConfig
2022:08:27-02:13:36.318 nfa_dm_check_set_config
2022:08:27-02:13:36.319 NfcAdaptation::HalWrite
2022:08:27-02:13:36.319 PN54X - Write requested.....
2022:08:27-02:13:36.319 PN54X - Invoking I2C Write.....
2022:08:27-02:13:36.322 len = 26 > 20021701291446666D010112020207FF03020003040164070103
2022:08:27-02:13:36.322 PN54X - I2C Write successful.....
2022:08:27-02:13:36.323 PN54X - Posting Fresh Write message.....
2022:08:27-02:13:36.323 PN54X - Tml Writer Thread Running................
2022:08:27-02:13:36.323 write successful status = 0x0
2022:08:27-02:13:36.323 dm_disc_mask = 0x146f7f
2022:08:27-02:13:36.323 tech_proto_mask = 0x00146F7F
2022:08:27-02:13:36.324 nfa_dm_check_set_config
2022:08:27-02:13:36.324 nfa_dm_set_total_duration
2022:08:27-02:13:36.324 NFC_DiscoveryStart
2022:08:27-02:13:36.324 NFC_DiscoveryStart status: 0xe3
2022:08:27-02:13:36.329 PN54X - I2C Read successful.....
2022:08:27-02:13:36.329 len = 5 > 4002020000
2022:08:27-02:13:36.330 PN54X - Posting read message.....
2022:08:27-02:13:36.330 read successful status = 0x0
2022:08:27-02:13:36.330 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-02:13:36.330 NfcAdaptation::HalDeviceContextDataCallback: len=5
2022:08:27-02:13:36.331 PN54X - Read requested.....
2022:08:27-02:13:36.331 PN54X - Invoking I2C Read.....
2022:08:27-02:13:36.331 NFC received rsp gid:0
2022:08:27-02:13:36.331 nci_proc_core_rsp opcode:0x2
2022:08:27-02:13:36.331 NFC_SET_CONFIG_REVT(0x5002)
2022:08:27-02:13:36.331 NfcAdaptation::HalWrite
2022:08:27-02:13:36.332 PN54X - Write requested.....
2022:08:27-02:13:36.332 PN54X - Invoking I2C Write.....
2022:08:27-02:13:36.334 len = 19 > 20021005300104310100320120380101500100
2022:08:27-02:13:36.335 PN54X - I2C Write successful.....
2022:08:27-02:13:36.335 PN54X - Posting Fresh Write message.....
2022:08:27-02:13:36.335 PN54X - Tml Writer Thread Running................
2022:08:27-02:13:36.335 write successful status = 0x0
2022:08:27-02:13:36.348 PN54X - I2C Read successful.....
2022:08:27-02:13:36.348 len = 5 > 4002020000
2022:08:27-02:13:36.348 PN54X - Posting read message.....
2022:08:27-02:13:36.349 read successful status = 0x0
2022:08:27-02:13:36.349 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-02:13:36.349 NfcAdaptation::HalDeviceContextDataCallback: len=5
2022:08:27-02:13:36.349 NFC received rsp gid:0
2022:08:27-02:13:36.350 nci_proc_core_rsp opcode:0x2
2022:08:27-02:13:36.350 NFC_SET_CONFIG_REVT(0x5002)
2022:08:27-02:13:36.350 NfcAdaptation::HalWrite
2022:08:27-02:13:36.350 PN54X - Read requested.....
2022:08:27-02:13:36.351 PN54X - Invoking I2C Read.....
2022:08:27-02:13:36.351 PN54X - Write requested.....
2022:08:27-02:13:36.351 PN54X - Invoking I2C Write.....
2022:08:27-02:13:36.353 len = 8 > 200205010002F401
2022:08:27-02:13:36.353 PN54X - I2C Write successful.....
2022:08:27-02:13:36.353 PN54X - Posting Fresh Write message.....
2022:08:27-02:13:36.353 PN54X - Tml Writer Thread Running................
2022:08:27-02:13:36.354 write successful status = 0x0
2022:08:27-02:13:36.357 PN54X - I2C Read successful.....
2022:08:27-02:13:36.357 len = 5 > 4002020000
2022:08:27-02:13:36.358 PN54X - Posting read message.....
2022:08:27-02:13:36.358 read successful status = 0x0
2022:08:27-02:13:36.359 phNxpNciHal_print_res_status: response status =STATUS_OK
2022:08:27-02:13:36.359 NfcAdaptation::HalDeviceContextDataCallback: len=5
2022:08:27-02:13:36.359 NFC received rsp gid:0
2022:08:27-02:13:36.360 nci_proc_core_rsp opcode:0x2
2022:08:27-02:13:36.360 NFC_SET_CONFIG_REVT(0x5002)
2022:08:27-02:13:36.360 NfcAdaptation::HalPrediscover
2022:08:27-02:13:36.361 NfcAdaptation::HalWrite
2022:08:27-02:13:36.361 > Polling Loop Started
2022:08:27-02:13:36.361 PN54X - Read requested.....
2022:08:27-02:13:36.362 PN54X - Invoking I2C Read.....
2022:08:27-02:13:36.362 PN54X - Write requested.....
2022:08:27-02:13:36.363 PN54X - Invoking I2C Write.....
2022:08:27-02:13:36.365 len = 22 > 21031309000101010201030180018101060174017001
2022:08:27-02:13:36.366 PN54X - I2C Write successful.....
2022:08:27-02:13:36.366 PN54X - Posting Fresh Write message.....
2022:08:27-02:13:36.367 PN54X - Tml Writer Thread Running................
2022:08:27-02:13:36.367 PN54X - I2C Read successful.....
2022:08:27-02:13:36.368 len = 4 > 41030105
2022:08:27-02:13:36.368 PN54X - Posting read message.....
2022:08:27-02:13:36.368 write successful status = 0x0
2022:08:27-02:13:36.369 read successful status = 0x0
2022:08:27-02:13:36.369 NfcAdaptation::HalDeviceContextDataCallback: len=4
2022:08:27-02:13:36.369 NFC received rsp gid:1
2022:08:27-02:13:36.370 p2p priority is running under bail out mode ONLY.
2022:08:27-02:13:36.370 event:0x4000
2022:08:27-02:13:36.371 state: IDLE (0), event: DISCOVER_RSP(1) disc_flags: 0x31
2022:08:27-02:13:36.371 NFC_Deactivate 4 (IDLE) deactivate_type:0
2022:08:27-02:13:36.371 new state: IDLE (0), disc_flags: 0x31
2022:08:27-02:13:36.372 NfcAdaptation::HalWrite
2022:08:27-02:13:36.372 PN54X - Read requested.....
2022:08:27-02:13:36.372 PN54X - Invoking I2C Read.....
2022:08:27-02:13:36.372 PN54X - Write requested.....
2022:08:27-02:13:36.373 PN54X - Invoking I2C Write.....
2022:08:27-02:13:36.374 len = 4 > 21060100
2022:08:27-02:13:36.374 PN54X - I2C Write successful.....
2022:08:27-02:13:36.375 PN54X - Posting Fresh Write message.....
2022:08:27-02:13:36.375 PN54X - Tml Writer Thread Running................
2022:08:27-02:13:36.375 write successful status = 0x0
2022:08:27-02:13:36.375 PN54X - I2C Read successful.....
2022:08:27-02:13:36.376 len = 4 > 41060106
2022:08:27-02:13:36.376 PN54X - Posting read message.....
2022:08:27-02:13:36.376 read successful status = 0x0
2022:08:27-02:13:36.377 NfcAdaptation::HalDeviceContextDataCallback: len=4
2022:08:27-02:13:36.377 NFC received rsp gid:1
2022:08:27-02:13:36.378 p2p priority is running under bail out mode ONLY.
2022:08:27-02:13:36.378 nfc_set_state 4 (IDLE)->4 (IDLE)
2022:08:27-02:13:36.378 nfa_dm_disc_data_cback
2022:08:27-02:13:36.378 event:0x4005
2022:08:27-02:13:36.379 state: IDLE (0), event: DEACTIVATE_RSP(7) disc_flags: 0x31
2022:08:27-02:13:36.379 new state: IDLE (0), disc_flags: 0x11
2022:08:27-02:13:36.379 PN54X - Read requested.....
2022:08:27-02:13:36.380 PN54X - Invoking I2C Read.....
Any idea??
