PN7150 NCI Problem
PN7150 NCI Problem
hanpengfei_666
i checked the pn7150 user guid and found that the NCI is not comprehensive,i would like to know whether there is a detailed explanation of NCI?
hanpengfei_666
from the NFC Forum,i don't find the NCI document ,can you help me find the document ? thank you!
Strooom
Hi, unfortunately, the NFC Forum specifications are only free of charge for members. If you are not a member, you need to purchase them and they are expensive.
Some years ago they were still free of charge on their website, so many older website/articles still refer to them as such but they are no longer available.
Here is my github repository for a PN7150 driver. Could be usefull to answer some questions on NCI you have.
https://github.com/Strooom/PN7150
Engineer by Day, Maker by Night
IvanRuiz
Please contact the NFC Forum for more details about their process to get it.
BR,
Ivan.
hanpengfei_666
Enable Low Power Card Detection Mode ,i learn from https://www.nxp.com.cn/docs/en/application-note/AN11757.pdf
There is my code , uint8_t NxpNci_CORE_CONF_EXTN[]={ 0x20, 0x02, 0x0D, 0x03, /* CORE_SET_CONFIG_CMD */
0xA0, 0x40, 0x01, 0x00, /* TAG_DETECTOR_CFG */
0xA0, 0x41, 0xFF, 0x04, /* TAG_DETECTOR_THRESHOLD_CFG */
0xA0, 0x43, 0x00, 0x50 /* TAG_DETECTOR_FALLBACK_CNT_CFG */
Oscilloscope screenshot as follow, i know that it is regular mode , i guess it may be my configuration problem. To verify my problem, I want to know the answer when i send NxpNci_CORE_CONF_EXTN[].
Thank you for your guidance.
On 9/17/2019 23:36,IvanRuiz<[email protected]> wrote:
NXP Community
Re: PN7150 NCI Problem
reply from IvanRuiz in NFC - View the full discussion
BR,
Ivan.
Reply to this message by replying to this email, or go to the message on NXP Community
Start a new discussion in NFC by email or at NXP Community
Following Re: PN7150 NCI Problem in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
hanpengfei_666
The problem has been solved. Thank you.IvanRuiz
su_can
请问您的问题是怎么解决的
IvanRuiz
You are welcome!
BR,
Ivan.
IvanRuiz
Please refer to the following document: https://www.nxp.com/docs/en/user-guide/UM10936.pdf
This User Manual describes the software interfaces. For more information, you may refer to the NFC Forum NCI document.
BR,
Ivan.
hanpengfei_666
hollo:
On 9/12/2019 01:56,IvanRuiz<[email protected]> wrote:
NXP Community
BR,
Ivan.
