PN7150 IRQ pin is not raised
yongha_yu
Hi~
I'm integrating libnfc-nci on my board consisting of PN1750 and imx8mQuad following the AN11697 document.
And i use alternative option. (3.2 Alternative to pn5xx_i2c kernel driver)
I am verifying the NFC function through the nfcDemoApp, but there is no response when I touch the NFC tag.
And NCI_MSG_CORE_GEN_ERR_STATUS is received.
my configuration is
 #define I2C_BUS         "/dev/i2c-2"
 #define I2C_ADDRESS     0x28  // 7bit address: 0x28
 #define PIN_INT         15 // NFC_IRQ: GPIO1_IO15 (J6), 15(= (1-1)*32 + 15)
 #define PIN_ENABLE      119    // NFC_VEN: GPIO4_23 (H6), 119(= (4-1)*32 + 23)
please let me know what I'm missing?
It's my nfcDemoApp log.
root@imx8mqevk:~# nfcDemoApp poll
## NFC demo ##
## Poll mode activated ##
... press enter to quit ...
NxpExtns: find found NXPLOG_TML_LOGLEVEL=(0x3)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXPLOG_TML_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_FWDNLD_LOGLEVEL=(0x3)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXPLOG_FWDNLD_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIX_LOGLEVEL=(0x3)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIX_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIR_LOGLEVEL=(0x3)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXPLOG_NCIR_LOGLEVEL=(0x3)
NxpFunc: phNxpLog_InitializeLogLevel: global =3, Fwdnld =3, extns =3, hal =3, tml =3, ncir =3, ncix =3
NxpHal: Entering phNxpNciHal_init_monitor
NxpHal: Returning with SUCCESS
NxpExtns: find found NXP_NFC_DEV_NODE=/dev/pn544
NxpExtns: GetNxpStrValue: NXP Config Parameter : NXP_NFC_DEV_NODE=/dev/pn544
NxpTml: phTmlNfc_i2c_open_and_configure Alternative NFC
NxpTml: NFC - Assign IO pins
NxpTml: Pin /sys/class/gpio/gpio15
NxpTml: System already has pin /sys/class/gpio/gpio15
NxpTml: Direction /sys/class/gpio/gpio15/direction
NxpTml: Pin 15 now an input
NxpTml: Edge /sys/class/gpio/gpio15/edge
NxpTml: Edge-string rising - 6
NxpTml: Pin 15 trigger on rising
NxpTml: Value /sys/class/gpio/gpio15/value
NxpTml: Pin /sys/class/gpio/gpio119
NxpTml: System already has pin /sys/class/gpio/gpio119
NxpTml: Direction /sys/class/gpio/gpio119/direction
NxpTml: Pin 119 now an output
NxpTml: Pin 119 now off
NxpTml: NFCHW - open I2C bus - /dev/i2c-2
NxpTml: NFC - open I2C device - 0x28
NxpTml: PN54X - Tml Reader Thread Started................
NxpTml: PN54X - Read requested.....
NxpTml: PN54X - Invoking I2C Read.....
NxpTml: PN54X - Tml Writer Thread Started................
NxpTml: PN54X - Tml Writer Thread Running................
NxpTml: PN54X - Write requested.....
NxpTml: PN54X - Invoking I2C Write.....
NxpHal: thread started
NxpNciX: len = 4 > 20000101
NxpTml: PN54X - I2C Write successful.....
NxpTml: PN54X - Posting Fresh Write message.....
NxpHal: write successful status = 0x0
NxpHal: Response timer started
NxpHal: Waiting after ext cmd sent
NxpTml: PN54X - I2C Read successful.....
NxpNciR: len = 6 > 400003001101
NxpTml: PN54X - Posting read message.....
NxpHal: read successful status = 0x0
NxpHal: Response timer stopped
NxpHal: Checking response
NxpNciX: len = 3 > 200100
NxpNciR: len = 28 > 40011900031E030008000102038081828302D002FF020004881001A0
NxpHal: NxpNci> FW Version: 10.1.a0
NxpHal: phNxpNciHal_deriveChipType HwVersion : 0x88
NxpHal: phNxpNciHal_deriveChipType NxpNci > Product : PN548C2
NxpExtns: find found NXP_I2C_FRAGMENTATION_ENABLED=(0x0)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_I2C_FRAGMENTATION_ENABLED=(0x0)
NxpNciX: len = 6 > 20030301A005
NxpNciR: len = 9 > 4003060001A0050100
NxpHal: phNxpNciHal_print_res_status: response status =STATUS_OK
NxpHal: i2c_fragmentation_status existing
NxpFwDnld: Allocating Mem for Dnld Context..
NxpExtns: GetNxpStrValue: NXP Config Parameter : NXP_NFC_FW_PATH=
NxpFwDnld: Ignoring Config :NFC FW Binary Path:
NxpExtns: GetNxpStrValue: NXP Config Parameter : NXP_NFC_FW_NAME=4
NxpFwDnld: Ignoring Config:NFC FW Binary :libpn548ad
NxpFwDnld: NFC FW Binary :/libpn548ad_fw.so
NxpFwDnld: @@@/libpn548ad_fw.so
NxpFwDnld: NULL handler : unable to load the binary file, verify binary path
NxpFwDnld: FW Image Length - ImageInfoLen 0
NxpFwDnld: FW Image Info Pointer - pImageInfo 0
NxpFwDnld: Image extraction Failed - invalid imginfo or imginfolen!!
NxpFwDnld: Error loading libpn54x_fw !!
NxpHal: FW version for FW file = 0x0
NxpHal: FW version from device = 0x1001a0
NxpFwDnld: Freeing Mem for Dnld Context..
NxpFunc: NfcAdaptation::HalDeviceContextCallback: event=0
NxpFunc: Nfc: nfc_main_hal_cback event: 0x0, status=0
NxpFunc: Nfc: NFC_TASK got NFC_TASK_EVT_TRANSPORT_READY.
NxpFunc: Nfc: nfc_set_state 1->2
NxpFunc: Nfc: nfc_ncif_send_cmd.
NxpFunc: NfcAdaptation::HalWrite
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=6
NxpFunc: Nfc: Process Event mt:2
NxpFunc: Nfc: NFC received rsp gid:0
NxpFunc: Nfc: nci_proc_core_rsp opcode:0x0
NxpFunc: Nfc: reset notification nfc_state : #### 1
NxpFunc: Nfc: NCI version mismatch!!:0x10 != 0x11
NxpFunc: Nfc: reset notification sending core init
NxpFunc: Nfc: nfc_ncif_check_cmd_queue : making p_buf NULL.
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=28
NxpFunc: Nfc: nci_proc_core_rsp opcode:0x1
NxpFunc: Nfc: FW Version: 10.1.a0
NxpFunc: Nfc: nfc_set_state 2->3
NxpFunc: NfcAdaptation::HalCoreInitialized
NxpExtns: find found NXP_ACT_PROP_EXTN=/
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_ACT_PROP_EXTN
NxpNciX: len = 3 > 2F0200
NxpNciR: len = 8 > 4F02050000009F97
NxpHal: NxpTml: PN54X - Read requested.....
NxpExtns: find found NXP_SYS_CLK_SRC_SEL=(0x1)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_SRC_SEL=(0x1)
NxpExtns: find found NXP_SYS_CLK_FREQ_SEL=
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLK_FREQ_SEL=(0x0)
NxpExtns: find found NXP_SYS_CLOCK_TO_CFG=(0x1)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_SYS_CLOCK_TO_CFG=(0x1)
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkSrcVal = 0x1
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x0
NxpFwDnld: gphNxpNciHal_fw_IoctlCtx.bClkFreqVal = 0x1
NxpFwDnld: Clock frequency value is wrong in config file, setting it as default
NxpNciX: len = 10 > 20030703A002A003A004
NxpNciR: len = 17 > 40030E0003A0020101A0030108A0040101
NxpNciX: len = 8 > 20020501A0030108
NxpTml: NxpHal: Waiting after ext cmd sent
NxpNciR: len = 5 > 4002020000
NxpTml: NxpHal: PN54X - Invoking I2C Read.....
NxpHal: phNxpNciHal_check_factory_reset file not present = /data/nfc/nfaStorage.bin1
NxpNciX: len = 26 > 20021702A0EA08FFFFFFFFFFFFFFFFA0EB08FFFFFFFFFFFFFFFF
NxpExtns: find found NXP_NFC_PROFILE_EXTN= D
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_NFC_PROFILE_EXTN
NxpNciX: len = 8 > 20020501A0440100
NxpHal: Performing TVDD Settings
NxpExtns: find found NXP_EXT_TVDD_CFG=(0x2)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_EXT_TVDD_CFG=(0x2)
NxpExtns: find found NXP_EXT_TVDD_CFG_2= d
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_EXT_TVDD_CFG_2
NxpNciX: len = 10 > 20020701A00E03066400
NxpTml: NxpHal: write successful status = 0x0
NxpHal: Performing RF Settings BLK 1
NxpTml: NxpExtns: PN54X - Read requested.....
find found NXP_RF_CONF_BLK_1= 5 D
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_1
NxpNciX: len = 166 > 2002A313A00D0604359001F401A00D06064401900300A00D060630B0011000A00D0606420200FFFFA00D03063F04A00D0620428800FFFFA00D0422442300A00D06222D50340C00A00D063242F800FFFFA00D06342D24370C00A00D06343386800070A00D0434442200A00D06422D15450D00A00D0446442200A00D06462D05590E00A00D0644428800FFFFA00D06562D059F0C00A00D0654428800FFFFA00D060A3380860070
NxpHal: Response timer sPuTTYtarted
NxpHal: Performing RF Settings BLK 2
NxpExtns: find found NXP_RF_CONF_BLK_2= W3
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_2
NxpNciX: len = 24 > 20021501A01D115733141700AA850080552A040063000000
NxpHal: Performing RF Settings BLK 3
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_3
NxpHal: Performing RF Settings BLK 4
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_4
NxpHal: Performing RF Settings BLK 5
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_5
NxpHal: Performing RF Settings BLK 6
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_RF_CONF_BLK_6
NxpHal: Performing NAME_NXP_CORE_CONF_EXTN Settings
NxpExtns: find found NXP_CORE_CONF_EXTN= ^@
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_CORE_CONF_EXTN
NxpNciX: len = 12 > 20020902A05E0101A0400100
NxpTml: NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_CORE_MFCKEY_SETTING
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_CORE_RF_FIELD
NxpNciX: len = 6 > 20030301A085
NxpNciR: len = 12 > 4003090001A0850450082800
NxpHal: Checking responseNxpTml: PN54X - Read requested.....
NxpExtns: find found NXP_CORE_STANDBY=/
NxpExtns: GetNxpByteArrayValue: NXP Config Parameter : NXP_CORE_STANDBY
NxpNciX: len = 4 > 2F000100
NxpNciR: len = 4 > 4F000100
NxpExtns: find found NXP_CORE_CONF= + (
NxpNciX: len = 46 > 20022B0D2801002101003001083101033304040302015401065001025B010060010E80010181010182010E180101
NxpNciX: len = 10 > 21010700010103000105
NxpNciR: len = 4 > 41010100
NxpFunc: NfcAdaptation::HalDeviceContextCallback: event=2
NxpFunc: Nfc: nfc_main_hal_cback event: 0x2, status=0
NxpFunc: Nfc: nfc_main_handle_hal_evt(): HAL event=0x2
NxpFunc: Nfc: nfc_set_state 3->4
NxpFunc: Nfc: nfc_set_conn_id conn_id:0, handle:1
NxpFunc: Nfc: nci_interfaces supported by NFCC: 0xf
NxpFunc: Nfc: [0]: intf_type:2 intf_mask: 0x4 is_supported:1
NxpFunc: Nfc: [1]: intf_type:3 intf_mask: 0x8 is_supported:1
NxpFunc: Nfc: [2]: vs intf_type:0x80 is_supported:1
NxpFunc: Nfc: [3]: intf_type:1 intf_mask: 0x2 is_supported:1
NxpFunc: Nfc: num_intf = 0x 4
NxpFunc: Nfc: max_maps[0].intf_type = 0x 2
NxpFunc: Nfc: max_maps[0].mode = 0x 3
NxpFunc: Nfc: max_maps[0].protocol = 0x 4
NxpFunc: Nfc: max_maps[1].intf_type = 0x 3
NxpFunc: Nfc: max_maps[1].mode = 0x 3
NxpFunc: Nfc: max_maps[1].protocol = 0x 5
NxpFunc: Nfc: max_maps[2].intf_type = 0x80
NxpFunc: Nfc: max_maps[2].mode = 0x 1
NxpFunc: Nfc: max_maps[2].protocol = 0x80
NxpFunc: Nfc: max_maps[3].intf_type = 0x 1
NxpFunc: Nfc: max_maps[3].mode = 0x 2
NxpFunc: Nfc: max_maps[3].protocol = 0x 3
NxpFunc: Nfc: max_maps[4].intf_type = 0x 0
NxpFunc: Nfc: max_maps[4].mode = 0x 0
NxpFunc: Nfc: max_maps[4].protocol = 0x 0
NxpFunc: Nfc: max_maps[5].intf_type = 0x 0
NxpFunc: Nfc: max_maps[5].mode = 0x 0
NxpFunc: Nfc: max_maps[5].protocol = 0x 0
NxpFunc: Nfc: max_maps[6].intf_type = 0x 0
NxpFunc: Nfc: max_maps[6].mode = 0x 0
NxpFunc: Nfc: max_maps[6].protocol = 0x 0
NxpNciX: len = 16 > 21000D04040302050303800180030201
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x5000
NxpFunc: NfcAdaptation::HalGetMaxNfcee
NxpFunc: Nfc: nfa_sys: enabling subsystems
NxpFunc: Nfc: nfa_sys_ptim_start_timer a23620c0
NxpFunc: Nfc: ptim timer start
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0x8, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0x18, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0x38, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0x78, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0xf8, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_hci_sys_enable ()
NxpNciR: len = 4 > 41000100
NxpFunc: Nfc: nfa_sys_ptim_start_timer a235fd10
NxpFunc: Nfc: NFA got event 0x0810
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 1 event: 0x0810
NxpFunc: Nfc: nfa_sys_ptim_stop_timer a235fd10
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=4
NxpFunc: Nfc: NFC received rsp gid:1
NxpNciX: len = 4 > 22000101
NxpNciR: len = 5 > 4200020001
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=5
NxpFunc: NxpTml: PN54X - Read requested.....
NxpFunc: Nfc: NFC received rsp gid:2
NxpFunc: Nfc: nci_proc_ee_management_rsp opcode:0x0
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x5004
NxpFunc: Nfc: nfa_ee_proc_evt: event=0x5004 int_event:0x20d
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x20d, State: 0
NxpFunc: Nfc: nfa_ee_nci_disc_rsp() em_state:0 cur_ee:0, num_nfcee:1
NxpFunc: Nfc: nfa_ee_report_disc_done() em_state:0 num_ee_expecting:1 notify_enable_done:0
NxpFunc: Nfc: nfa_ee_nci_disc_rsp() em_state:0 cur_ee:0 num_ee_expecting:1
NxpNciR: len = 8 > 6200050101010100
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=8
NxpFunc: Nfc: Process Event mt:3
NxpFunc: Nfc: NFC received ntf gid:2
NxpFunc: Nfc: nci_proc_ee_management_ntf opcode:0x0
NxpFunc: Nfc: nfcee_id: 0x1 num_interface:0x1/0x1, num_tlvs:0x0
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x5005
NxpFunc: Nfc: nfa_ee_proc_evt: event=0x5005 int_event:0x20e
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x20e, State: 0
NxpFunc: Nfc: recived dis_ntf; stopping timer
NxpFunc: Nfc: nfa_sys_ptim_stop_timer a23620c0
NxpFunc: Nfc: ptim timer stop
NxpFunc: Nfc: nfa_ee_nci_disc_ntf() em_state:0 ee_flags:0x0 cur_ee:0 num_ee_expecting:1
NxpFunc: Nfc: nfa_ee_nci_disc_ntf cur_ee:1
NxpFunc: Nfc: nfa_ee_report_disc_done() em_state:1 num_ee_expecting:0 notify_enable_done:1
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0xfc, enable_cplt_mask=0x1fc
NxpFunc: Nfc: nfa_hci_ee_info_cback (): 0
NxpFunc: Nfc: NFA_EeGetInfo em_state:1 cur_ee:1
NxpFunc: Nfc: xx:0 max_ret:2, num_ret:0 ee_status:0x1
NxpFunc: Nfc: num_ret:1
NxpNciX: len = 9 > 200406030101020101
NxpFunc: Nfc: NFA_AllEeGetInfo em_state:1 cur_ee:1
NxpFunc: Nfc: xx:0 max_ret:3, num_ret:0 ee_status:0x1
NxpNciR: len = 7 > 40040400FF0103
NxpFunc: NfcAdaptation::HalDeviceContextDataCallback: len=7
NxpFunc: Nfc: nci_proc_core_rsp opcode:0x4
NxpFunc: Nfc: nfc_set_conn_id conn_id:3, handle:2
NxpFunc: Nfc: nfa_hciu_alloc_gate id:65 app_handle: 0x0000
NxpFunc: Nfc: nfa_hciu_send_msg pipe_id:1 Type: 0 Inst: 3 len: 0
NfcHcpX:8103
NxpFunc: Nfc: nfc_ncif_send_data :3, num_buff:1 qc:0
NxpNciX: len = 5 > 0300028103
NxpNciR: len = 6 > 600603010301
NxpFunc: Nfc: NFC received ntf gid:0
NxpTml: NxpFunc: Nfc: nci_proc_core_ntf opcode:0x6
NxpNciR: len = 5 > 0300028180
NxpFunc: Nfc: Process Event mt:0
NxpFunc: Nfc: NFC received data
NxpFunc: Nfc: nfc_ncif_proc_data 0x030002
NxpFunc: Nfc: nfc_ncif_proc_data len:2
NfcHcpR:8180
NxpFunc: Nfc: nfa_hci_conn_cback Recvd data pipe:1 Type: 2 Inst: 0 chain:1 reassm:0 len:2
NxpFunc: Nfc: nfa_hci_handle_admin_gate_rsp LastCmdSent: 3 App: 0x0000 Gate: 0x00 Pipe: 0x01
NxpFunc: Nfc: nfa_hciu_send_msg pipe_id:1 Type: 0 Inst: 1 len: 4
NfcHcpX:810103020304
NxpHal: > Going through workaround - set host list
NxpHal: > Going through workaround - set host list - END
NxpNciX: len = 8 > 03000581010302C0
NxpFunc: Nfc: NFA got event 0x0813
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 1 event: 0x0813
NfcHcpR:NxpTml: 8180
NxpFunc: Nfc: nfa_hci_handle_admin_gate_rsp LastCmdSent: 1 App: 0x0000 Gate: 0x00 Pipe: 0x01
NxpFunc: Nfc: nfa_hciu_send_msg pipe_id:1 Type: 0 Inst: 1 len: 9
NfcHcpX:810101882f7e66432f7e66
NxpNciX: len = 14 > 03000B810101882F7E66432F7E66
NfcHcpR:8180
NxpNciX: len = 5 > 2201020101
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 2 event: 0x0813
NxpNciR: len = 4 > 42010100
NxpFunc: Nfc: nci_proc_ee_management_rsp opcode:0x1
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x5006
NxpFunc: Nfc: nfa_ee_proc_evt: event=0x5006 int_event:0x20f
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x20f, State: 1
NxpFunc: Nfc: nfa_ee_nci_mode_set_rsp() handle:0x01 mode:1
NxpFunc: Nfc: nfa_ee_find_ecb ()
NxpFunc: Nfc: status:0 ecb_flags :0x00 ee_cfged:0x00 ee_status:0
NxpFunc: Nfc: nfa_hci_ee_info_cback (): 2
NxpFunc: Nfc: nfa_dm_is_active () flags:0x21
NxpFunc: Nfc: nfa_ee_report_discover_req_evt DM is not active
NxpNciR: len = 8 > 6200050202018000
NxpFunc: Nfc: nfcee_id: 0x2 num_interface:0x1/0x1, num_tlvs:0x0
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x20e, State: 1
NxpFunc: Nfc: nfa_ee_nci_disc_ntf() em_state:1 ee_flags:0x0 cur_ee:1 num_ee_expecting:0
NxpFunc: Nfc: nfa_ee_nci_disc_ntf cur_ee:2
NxpFunc: Nfc: nfa_sys_ptim_timer_update expired: a235fd10
NxpFunc: Nfc: NFA got event 0x0812
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 2 event: 0x0812
NxpFunc: Nfc: nfa_hci_rsp_timeout () State: 2 Cmd: 1
NxpFunc: Nfc: nfa_hciu_send_msg pipe_id:1 Type: 0 Inst: 2 len: 1
NfcHcpX:810204
NxpNciX: len = 6 > 030003810204
NxpNciR: len = 6 > 030003818000
NxpFunc: Nfc: nfc_ncif_proc_data 0x030003
NxpFunc: Nfc: nfc_ncif_proc_data len:3
NfcHcpR:818000
NxpFunc: Nfc: nfa_hci_conn_cback Recvd data pipe:1 Type: 2 Inst: 0 chain:1 reassm:0 len:3
NxpFunc: Nfc: nfa_hci_handle_admin_gate_rsp LastCmdSent: 2 App: 0x0000 Gate: 0x00 Pipe: 0x01
NxpFunc: Nfc: nfa_hci_startup_complete (): Status: 0
NxpFunc: Nfc: nfa_sys_cback_notify_enable_complete () enable_cplt_flags=0x1fc, enable_cplt_mask=0x1fc
NxpFunc: nfaDeviceManagementCallback: enter; event=0x0
NxpFunc: nfaDeviceManagementCallback: NFA_DM_ENABLE_EVT; status=0x0
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 3 event: 0x0813
NxpFunc: Nfc: NFA got event 0x0811
NxpFunc: Nfc: nfa_hci_evt_hdlr state: 3 event: 0x0811
NxpExtns: find found NXP_NFC_PROPRIETARY_CFG=p
NxpExtns: GetNxpStrValue: NXP Config Parameter : NXP_NFC_PROPRIETARY_CFG=p
NxpExtns: find found NXP_NFC_MAX_EE_SUPPORTED=(0x0)
NxpExtns: GetNxpNumValue: NXP Config Parameter : NXP_NFC_MAX_EE_SUPPORTED=(0x0)
NxpFunc: Configure: Overriding NFA_EE_MAX_EE_SUPPORTED to use 0
NxpFunc: RoutingManager::RoutingManager(): default route is 0x00
NxpFunc: initialize:HOST_LISTEN_TECH_MASK=7;
NxpFunc: RoutingManager::initialize(): try ee register
NxpFunc: Nfc: NFA_EeRegister()
NxpFunc: Nfc: NFA got event 0x0201
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x201, State: 1
NxpFunc: RoutingManager::nfaEeCallback: NFA_EE_REGISTER_EVT; status=0
NxpFunc: NxpFunc: Nfc: NFA_CeSetIsoDepListenTech (): 0x3
nfaEeCallback: NFA_EE_DISCOVER_REQ_EVT; status=0x0; num ee=0
NxpFunc: Nfc: NFA got event 0x0703
NxpFunc: Nfc: NFA_AllEeGetInfo em_state:1 cur_ee:2
NxpFPuTTYPuTTYunc: NxpFunc: Nfc: nfa_ce_handle_event event: 0x703, flags: 00000000
NxpFunc: Nfc: NFA got event 0x0701
NxpFunc: Nfc: nfa_ce_handle_event event: 0x701, flags: 00000000
NxpFunc: Nfc: Registering UICC/ESE/Felica/Type-4 tag listener. Type=1
NxpFunc: Nfc: NFA_CE: adding listen_info entry 1
NxpFunc: Nfc: CE_T4tRegisterAID (): registering callback for wildcard AID
NxpFunc: Nfc: CE_T4tRegisterAID (): handle 0x04 registered (for wildcard AID)
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0x140000
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0x140000, xx=0
NxpFunc: Nfc: nfa_ce_api_reg_listen: registered handle 0x0301
NxpFunc: RoutingManager::stackCallback: event=0x15
NxpFunc: RoutingManager::stackCallback: NFA_CE_REGISTERED_EVT; status=0x0; h=0x301
NxpFunc: Nfc: num_ret:0
NxpFunc: nativeNfcTag_registerNdefTypeHandler
NxpFunc: Nfc: NFA_RegisterNDefTypeHandler (): handle whole ndef message: 1, tnf=0xff
NxpFunc: Nfc: NFA got event 0x0115
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0x15
NxpFunc: Nfc: Default NDEF handler successfully registered.
NxpFunc: Nfc: NDEF handler successfully registered. Handle=0x00000200
NxpFunc: ndefHandlerCallback: event=0, eventData=0xffff9bffe8e8
NxpFunc: ndefHandlerCallback: NFA_NDEF_REGISTER_EVT; status=0x0; h=0x200
NxpFunc: NfcTag::resetTechnologies
NxpFunc: nativeNfcManager_doInitialize: NAME_POLLING_TECH_MASK mask=0xEF
NxpFunc: nativeNfcManager_doInitialize: tag polling tech mask=0xEF
NxpFunc: nativeNfcManager_doInitialize: P2P listen tech mask=0xC5
NxpFunc: Nfc: NFA_SetRfDiscoveryDuration ()
NxpFunc: Nfc: NFA got event 0x0110
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0x10
NxpFunc: nativeNfcManager_doInitialize: nfc enabled = 1
NxpFunc: nativeNfcManager_doInitialize: exit
NxpFunc: nativeNfcSnep_registerClientCallback:
NxpFunc: Nfc: NFA_SnepRegisterClient ()
NxpFunc: Nfc: NFA got event 0x0503
NxpFunc: Nfc: nfa_snep_evt_hdlr(): Event 0x503
NxpFunc: Nfc: nfa_snep_reg_client ()
NxpFunc: Nfc: LLCP_RegisterClient (): link_type = 0x2
NxpFunc: Nfc: LLCP_RegisterClient (): Registered SAP = 0x20
NxpFunc: nfaSnepClientCallback: snepEvent= 0
NxpFunc: nfaSnepClientCallback: NFA_SNEP_REG_EVT; Status: 0x0000
NxpFunc: nfaSnepClientCallback: NFA_SNEP_REG_EVT; Client Register Handle: 0x0700
NxpFunc: nativeNfcManager_enableDiscovery: enter; tech_mask = ef
NxpFunc: nativeNfcTag_acquireRfInterfaceMutexLock: try to acquire lock
NxpFunc: nativeNfcTag_acquireRfInterfaceMutexLock: sRfInterfaceMutex lock
NxpFunc: nativeNfcManager_enableDiscovery: Disable p2pListening
NxpFunc: enableP2pListening: enter isEnable: 0 mIsP2pListening: 0
NxpFunc: enableP2pListening: exit; mIsP2pListening: 0
NxpFunc: stopPolling_rfDiscoveryDisabled: disable polling
NxpFunc: Nfc: NFA_DisablePolling ()
NxpFunc: Nfc: NFA got event 0x0107
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0x7
NxpFunc: Nfc: nfa_dm_act_disable_polling ()
NxpFunc: nfaConnectionCallback: event= 1
NxpFunc: nfaConnectionCallback: NFA_POLL_DISABLED_EVT: status = 3
NxpFunc: startPolling_rfDiscoveryDisabled: enable polling
NxpFunc: Nfc: NFA_EnablePolling () 0xEF
NxpFunc: Nfc: NFA got event 0x0106
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0x6
NxpFunc: Nfc: nfa_dm_act_enable_polling ()
NxpFunc: Nfc: nfa_dm_start_polling ()
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0x3d7f
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0x3d7f, xx=1
NxpFunc: nfaConnectionCallback: event= 0
NxpFunc: nfaConnectionCallback: NFA_POLL_ENABLED_EVT: status = 0
NxpFunc: startPolling_rfDiscoveryDisabled: wait for enable event
NxpFunc: nativeNfcManager_enableDiscovery: Enable p2pListening
NxpFunc: enableP2pListening: enter isEnable: 1 mIsP2pListening: 0
NxpFunc: Nfc: NFA_P2pSetListenTech (): tech_mask:0xC5
NxpFunc: Nfc: NFA got event 0x010D
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0xd
NxpFunc: Nfc: nfa_dm_set_p2p_listen_tech () tech_mask = 197
NxpFunc: Nfc: nfa_p2p_update_listen_tech () tech_mask = 0xc5
NxpFunc: nfaConnectionCallback: event= 33
NxpFunc: nfaConnectionCallback: NFA_SET_P2P_LISTEN_TECH_EVT
NxpFunc: enableP2pListening: exit; mIsP2pListening: 1
NxpFunc: RoutingManager::disableRoutingToHost() enter
NxpFunc: Nfc: NFA_EeSetDefaultProtoRouting(): handle:<0x0>protocol_mask:<0x0>/<0x0>/<0x0><0x0><0x0>
NxpFunc: Nfc: NFA got event 0x0205
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x205, State: 1
NxpFunc: Nfc: nfa_ee_update_route_size nfcee_id:0x0 size_mask:0
NxpFunc: Nfc: nfa_ee_total_lmrt_size size:0
NxpFunc: Nfc: nfa_dm_is_active () flags:0x5
NxpFunc: Nfc: nfa_sys_ptim_start_timer a2362090
NxpFunc: RoutingManager::nfaEeCallback: NFA_EE_SET_PROTO_CFG_EVT; status=0x0
NxpFunc: Nfc: NFA_EeUpdateNow()
NxpFunc: Nfc: NFA got event 0x0209
NxpFunc: Nfc: nfa_ee_evt_hdlr (): Event 0x209, State: 1
NxpFunc: Nfc: nfa_sys_ptim_stop_timer a2362090
NxpFunc: Nfc: nfa_ee_rout_timeout()
NxpFunc: Nfc: nfa_ee_need_recfg() ee_cfged: 0x80 ee_cfg_sts: 0x00
NxpFunc: Nfc: 0: ecb_flags : 0x04, mask: 0x08
NxpFunc: Nfc: 1: ecb_flags : 0x00, mask: 0x01
NxpFunc: Nfc: 2: ecb_flags : 0x00, mask: 0x02
NxpFunc: Nfc: nfa_ee_report_update_evt ee_wait_evt:0x10 wait_rsp:0
NxpFunc: RoutingManager::nfaEeCallback: unknown event=9 ????
NxpFunc: startRfDiscovery: is start=1
NxpFunc: Nfc: NFA_StartRfDiscovery ()
NxpFunc: Nfc: NFA got event 0x010E
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0xe
NxpFunc: Nfc: nfa_dm_act_start_rf_discovery ()
NxpFunc: Nfc: nfa_dm_start_rf_discover ()
NxpFunc: Nfc: nfa_ee_get_tech_route(): 1
NxpFunc: Nfc: 0x0, 0x0, 0x0, 0x0
NxpFunc: Nfc: requested_disc_mask = 0x140000, xx=0
NxpFunc: Nfc: listen_mask value after NFC-A = 0x40000
NxpFunc: Nfc: listen_mask value after NFC-B = 0x140000
NxpFunc: Nfc: listen_mask value after NFC-F = 0x140000
NxpFunc: Nfc: listen_mask value after NFC-B Prime = 0x140000
NxpFunc: Nfc: dm_disc_mask = 0x0
NxpFunc: Nfc: listen_mask value after T1T and T2T = 0x140000
NxpFunc: Nfc: listen_mask value after NFC-DEP = 0x140000
NxpFunc: Nfc: nfa_dm_cb.disc_cb.entry[0].selected_disc_mask = 0x140000
NxpFunc: Nfc: requested_disc_mask = 0x3d7f, xx=1
NxpFunc: Nfc: listen_mask value after NFC-A = 0x0
NxpFunc: Nfc: listen_mask value after NFC-B = 0x0
NxpFunc: Nfc: listen_mask value after NFC-F = 0x0
NxpFunc: Nfc: listen_mask value after NFC-B Prime = 0x0
NxpFunc: Nfc: dm_disc_mask = 0x140000
NxpFunc: Nfc: listen_mask value after T1T and T2T = 0x0
NxpFunc: Nfc: listen_mask value after NFC-DEP = 0x0
NxpFunc: Nfc: nfa_dm_cb.disc_cb.entry[1].selected_disc_mask = 0x3d7f
NxpFunc: Nfc: supported tech list is 0x00 for given nfcee_id: 0x2
NxpFunc: Nfc: nfa_p2p_set_config ()
NxpFunc: Nfc: LLCP_GetDiscoveryConfig ()
NxpFunc: Nfc: nfa_dm_check_set_config ()
NxpNciX: len = 26 > 20021701291446666D010111020207FF03020003040164070103
NxpFunc: Nfc: dm_disc_mask = 0x143d7f
NxpFunc: Nfc: nfa_dm_set_rf_listen_mode_config () tech_proto_mask = 0x00143D7F
NxpFunc: Nfc: nfa_dm_get_sak:HOST_LISTEN_TECH_MASK=0x07;
NxpFunc: Nfc: nfa_dm_set_rf_listen_mode_config: sens_info=0x020;
NxpFunc: Nfc: nfa_dm_set_total_duration ()
NxpFunc: Nfc: NFC_DiscoveryStart
NxpFunc: Nfc: NFC_DiscoveryStart status: 0xe3
NxpFunc: Nfc: nci_proc_core_rsp opcode:0x2
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x5002
NxpNciX: len = 19 > 20021005320120300104310100380101500100
NxpNciX: len = 8 > 200205010002F401
NxpTml: NxpFunc: NfcAdaptation::HalPrediscover
NxpHal: > Polling Loop Started
NxpNciX: len = 22 > 21031309000101010201030105018001810106017001
NxpNciR: len = 4 > 41030100
NxpFunc: Nfc: returning TRUE
NxpFunc: Nfc: nfa_dm_disc_discovery_cback (): event:0x4000
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): state: 0, event:1 disc_flags: 0x31
NxpFunc: Nfc: nfa_dm_disc_new_state(): old_state: 0, new_state: 1 disc_flags: 0x11
NxpFunc: Nfc: nfa_ce_discovery_cback(): event:0x00
NxpFunc: Nfc: nfa_ce_handle_disc_start (status=0x0)
NxpFunc: Nfc: nfa_dm_poll_disc_cback (): event:0x00
NxpFunc: nfaConnectionCallback: event= 30
NxpFunc: nfaConnectionCallback: NFA_RF_DISCOVERY_STARTED_EVT: status = 0
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): new state: 1, disc_flags: 0x1
NxpFunc: nativeNfcTag_releaseRfInterfaceMutexLock: sRfInterfaceMutex unlock
NxpFunc: nativeNfcManager_enableDiscovery: exit
NxpFunc: nativeNfcSnep_startServer:
NxpFunc: startRfDiscovery: is start=0
NxpFunc: Nfc: NFA_StopRfDiscovery ()
NxpFunc: Nfc: NFA got event 0x010F
NxpFunc: Nfc: nfa_dm_evt_hdlr event: 0xf
NxpFunc: Nfc: nfa_dm_act_stop_rf_discovery ()
NxpFunc: Nfc: nfa_dm_rf_deactivate () deactivate_type:0x0
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): state: 1, event:6 disc_flags: 0x2
NxpFunc: Nfc: NFC_Deactivate 4 deactivate_type:0
NxpNciX: len = 4 > 21060100
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): new state: 1, disc_flags: 0x22
NxpFunc: Nfc: nfa_sys_ptim_stop_timer a235fc40
NxpFunc: Nfc: Stopped presence check timer (if started)
NxpNciR: len = 4 > 41060100
NxpFunc: Nfc: P2P_Prio_Logic
NxpFunc: Nfc: nfa_dm_p2p_prio_logic type = 0xff
NxpFunc: Nfc: nfc_set_state 4->4
NxpFunc: Nfc: nfa_dm_disc_data_cback ()
NxpFunc: Nfc: nfa_dm_disc_discovery_cback (): event:0x4005
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): state: 1, event:7 disc_flags: 0x22
NxpFunc: Nfc: nfa_dm_disc_new_state(): old_state: 1, new_state: 0 disc_flags: 0x2
NxpFunc: nfaConnectionCallback: event= 31
NxpFunc: nfaConnectionCallback: NFA_RF_DISCOVERY_STOPPED_EVT: status = 0
NxpFunc: notifyPollingEventwhileNfcOff: sDiscCmdwhleNfcOff=0
NxpFunc: nativeNfcTag_getReconnectState = 0x0
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): new state: 0, disc_flags: 0x0
NxpFunc: Nfc: NFA got event 0x0502
NxpFunc: Nfc: nfa_snep_evt_hdlr(): Event 0x502
NxpFunc: Nfc: nfa_snep_reg_server ()
NxpFunc: Nfc: LLCP_RegisterServer (): SAP:0x4, link_type:0x2, ServiceName:<urn:nfc:sn:snep>
NxpFunc: Nfc: LLCP_RegisterServer (): Registered SAP = 0x04
NxpFunc: Nfc: nfa_p2p_enable_listening () sys_id = 5, update_wks = 1
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0xc480000
NxpFunc: Nfc: nfa_dm_add_rf_discover () disc_mask=0xc480000, xx=2
NxpFunc: nfaSnepServerCallback: Function Entry snepEvent: 0x0
NxpFunc: nfaSnepServerCallback: NFA_SNEP_REG_EVT; Status: 0x0000
NxpFunc: nfaSnepServerCallback: NFA_SNEP_REG_EVT; Server Register Handle: 0x0701
NxpFunc: NxpFunc: Nfc: NFA got event 0x010E
NxpFunc: Nfc: requested_disc_mask = 0xc480000, xx=2
NxpFunc: Nfc: listen_mask value after NFC-A = 0x4080000
NxpFunc: Nfc: listen_mask value after NFC-B = 0x4080000
NxpFunc: Nfc: listen_mask value after NFC-F = 0xc480000
NxpFunc: Nfc: listen_mask value after NFC-B Prime = 0xc480000
NxpFunc: Nfc: listen_mask value after T1T and T2T = 0xc480000
NxpFunc: Nfc: listen_mask value after NFC-DEP = 0xc480000
NxpFunc: Nfc: nfa_dm_cb.disc_cb.entry[2].selected_disc_mask = 0xc480000
NxpNciX: len = 26 > 20021701291446666D010111020207FF03020013040164070103
NxpFunc: Nfc: dm_disc_mask = 0xc5c3d7f
NxpFunc: Nfc: nfa_dm_set_rf_listen_mode_config () tech_proto_mask = 0x0C5C3D7F
NxpFunc: Nfc: nfa_dm_set_rf_listen_mode_config: sens_info=0x060;
NxpNciX: len = 29 > 20021A02611446666D010111020207FF03020013040164070103600107
NxpTml: NxpFunc: NfcAdaptation::HalWrite
NxpNciX: len = 16 > 20020D04320160310100380101500102
NxpNciX: len = 28 > 2103190C000101010201030105018001810182018301850106017001
NxpFunc: Nfc: nfa_p2p_discovery_cback (): event:0x00
Waiting for a Tag/Device...
NxpNciR: len = 4 > 600701A1
NxpFunc: Nfc: nci_proc_core_ntf opcode:0x7
NxpFunc: Nfc: nfa_dm_nfc_response_cback () event=0x500d
NxpFunc: Nfc: nfa_dm_disc_sm_execute(): state: 1, event:10 disc_flags: 0x1
Tags (4)
surveyzones
jimmychan
Seems you got -6 when setting the gpio pin irq.
Please check this example.
https://community.nxp.com/t5/i-MX-Processors/How-to-enable-interrupts-of-EXP-GPIOs-from-PCA6416-in-I...
yongha_yu
I followed your guide and confirmed that PN7150 works normally by using pn5xx_i2c kernel driver.
But I'm still not sure why it doesn't work alternative way.
Thank you.
