PN7150 Antenna Selftest using libnfc-nci
1,040件の閲覧回数
gzema
I'm looking for a sample utility src code for PN7150 antenna testing using libnfc-nci under linux.
The tool shall use nfcFactory_AntennaSelfTest() under linux_nfc_factory_api.c
Does anybody has done it?
thanks
1,024件の閲覧回数
Kan_Li
Hi @gzema ,
I am sorry, but so far no such kind of source code available, while you may build your own application based on https://github.com/NXP/nfc-linux_NfcFactoryTestApp .
Kan
