PN553 PN80T for Android 8.1
4,806 次查看
lifusong
where is the library, driver and docs for PN553 work on Android 8.1
the processor is rk3399 http://www.rock-chips.com/a/en/products/RK33_Series/2016/0419/758.html
thanks
标记 (2)
4 回复数
4,239 次查看
fangfang
Hello
PN533 is not supported under Android. So NXP does not provide PN533 driver/library  on Android.
Hope it help you. Have a nice day.
Best Regards
4,239 次查看
lifusong
Hi   we use  AN11836 PN553 PN80T,   and sorry ,i write error, not pn533 ,, and is pn553
4,239 次查看
fangfang
PN553 is not a mass market product. Please contact local NXP CAS team or local distributor for better support.
4,239 次查看
lifusong
thanks
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
