PN5190B_012.s1p source file for NFC reader Antenna simulation by RFSim99
DavidDeng
KaiLi
Hello @DavidDeng
So, your request is as the title, is that right? If correct, then just say sorry to you, there is unavailable for PN5190B_012.s1p source file.
DavidDeng
Hi @KaiLi
Yes, you're right. Thank you for your kind reply, Kelly!
So could you help check if it will be available later?
KaiLi
Hello @DavidDeng
Ok, no problem. If any news and update to you.
