PN5180 ISO 14443 type B card reading configuration
1,237 次查看
ASKalpa
Good afternoon,
I am currently trying to configure via SPI the PN5180 in order to read ISO 14443 Type B cards following AN12650 (Using the PN5180 without library) instructions. Unfortunately the application note shows only as example the PN5180 configuration for reading ISO 144443 type A cards, I tried to adapt it to my purpose without results. Is it possible to have a configuration example to read ISO 14443 type B cards?
Thank you in advice,
Andrea
标记 (1)
1 回复
1,206 次查看
Fabian_R
Thank you for using our products Andrea, unfortunately, our free online support is very limited for projects that are out of our scope. In this case, I cannot provide any further help for a type B card reading without the use of our NFC Reader Library and please check the example DiscoveryLoop. It does support Type B cards and will return a UID reading, maybe this example will provide any help for your project.
My apologies for not being able to provide any further help, I´m really sorry.
Fabian
