PN 7150 Single ended antenna desing
alikarakaş
i need single ended full range antenna for pn7150. İm using 50 ohm coaxial cable and im switching 8 antena with pe42482 RF switch ic.
IvanRuiz
It will be helpful to refer to the Antenna Design and Matching Guide in the Application Note section:
PN7150|High Performance Plug'n Play NFC for OS|NXP
Have a good day.
Ivan.
