Noise on board with PN512
piotrh
Hello, my own board with PN512 generates noise on higher(12-18) harmonic frequences (162.72, 176.28, 189.94, 203.4, 216.96, 230.52 and 244.08MHz).
On power line there are 100uF(tantal), 100nF(ceramic) and 100pF(ceramic) capacitors, on NRSTPD line 100pF, on SDA/SCL 33pF.
I tried with different capacitors, but still no success.
What else can I try to suppress this noise?
Fabian_R
My apologies for the delay in answering back, Have you checked our antenna design video series, I'm posting the link for this guide. I'll recommend you to check 4th video of the series where you can debug and optimize your design with an antenna already printed.
https://www.nxp.com/video/nfc-antenna-design-4-optimization-debugging:ANTENNA-DEBUGGING-VIDEO
Thank you for using our products, we really appreciate your preference.
Fabian
piotrh
Thank you for answer. Now I know, what probably is wrong - long traces from PN512 to EMC filter.
Piotr
Fabian_R
Fabian
