No response from NFC Tag while authenticating the tag with password
AR-2195
Good morning community members
I have a question following the previous question posted about authenticating the tag with password which have been followed.
All the steps mentioned in the previous question have been followed and it solved the problem for authenticating the tag.
Problem now is getting a response from the tag, which the tag should be responsive to the command of PWD_AUTH because all the required command to wake up the tag have been implemented in the code.
Do help me please.
I am using the pn532 adafruit library.
jimmychan
As you are using adafruit library, it is better to ask in the Adafruit forum: https://forums.adafruit.com/
