NTAG I2C as passive tag, floating pins
1,761件の閲覧回数
vch
I intend on using a NTGA I2C chip in a passive NFC tag setup for usage in a mobile phone dock. Can I leave the pins SDA, SCL and FD floating? Also I do not need energy harvesting, does that mean I just connect VCC to VOUT and VSS? Will I need resistors placed between VSS and VOUT or VOUT and VCC?
Thank you for helping out a NFC newbie!
タグ(3)
1,730件の閲覧回数
fangfang
Hello @vch .
Yes, you can floating them if you don't use it.
No. you don't follow the steps for the energy harvesting if you don't use it.
You can refer to the NTAG® for Tags & Labels for your application if you don't I2C and energy harvesting function.
You will find the more information as the link.
https://www.nxp.com/products/rfid-nfc/nfc-hf/ntag-for-tags-labels:NTAG-TAGS-AND-LABELS.
Have a nice day.
