NTAG I2C Plus unable to read/write through I2c
3,395件の閲覧回数
niranjan_rao
hello,
I am working on NT3H2211 NTAG I2C.
I Could read/ write to the NFC chip through the host microcontroller and a NFC device.
Now all of sudden the I can neither read nor write into the NFC chip through I2C from the host MCU, but I can read/ write NDEF mesages through my mobile phone (NFC device). I can also read registers using the NXP Android app.
I check the I2C pin, everything is correct.
Can someone please tell me whats going on here?
Thank You
Rao
6 返答(返信)
2,953件の閲覧回数
eljeffo
Are you able to detect other i2c devices when attached to the same bus?
2,953件の閲覧回数
niranjan_rao
Yes,  and I tried with a new ntag and I can read and write to it from the same bus
2,953件の閲覧回数
Kan_Li
Was the problem still there after change the ntag?
2,953件の閲覧回数
niranjan_rao
With new Ntag I can read and write through I2C,  with the old Ntag I cannot read and write through I2C
2,953件の閲覧回数
eljeffo
Try scanning all i2c addresses and confirm your chip is on the i2c address you expect. (check for NACKs)
2,953件の閲覧回数
niranjan_rao
Hello Jeff,
I scanned through all the I2C address, I get NAKs
