NHS3152 I2C design guides
已解决
跳至解决方案
2,171 次查看
ManuelG_Eurecat
I would like to know if the external pull-up resistances in the I2C lines are necessary, as the pins should be programabble to have the internal pull-up resistance active, right?
Thanks in advance,
Manuel
标记 (3)
1 解答
2,162 次查看
fangfang
Generally, The clock line and data line of I2C are Open Drain , so both lines need to be pulled up to the appropriate level with resistors .
Have a nice day.
在原帖中查看解决方案
1 回复
2,163 次查看
fangfang
Have a nice day.
