NFC error codes
NFC error codes
2,131 次查看
sanket_joshi
PN5321A3HN/C106 is being used for NFC in my project.Issues faced due to unknown error codes.Can NXP share NFC error codes ?Where can i get error codes and there description?
1,803 次查看
Jonathan_Iglesias
Dear SANKET JOSHI,
for the Error codes for this device please check the datasheet usually every command has the responses you can get aswell as the errors that the PN can return. please check the following link
https://www.nxp.com/docs/en/nxp/data-sheets/PN532_C1.pdf
Jonathan
