I had a quick question about the configuration of the MIKROELEKTRONIKA NFC READER-WRITER.
Can I configure the reader to send an unmodulated signal (Modulator-disable) , in others words sending only the 13.56 MHz carrier?
Is there GUI to change the settings? And would i be able to see the demod output on board using an oscilloscope?
Looking forward to hearing from you.
Preetha
