NFC TAG'S READER
NFC TAG'S READER
mohamednacer_sa
Hi,I have started my new project which is a NFC tag's reader I choose to work with PN7150 but I dont know which version to use.
Can anyone helps me to select the suitable one
thank you
nxf58474
Hi mohamednacer.sayahi@ensi-uma.tn,
Hope you are doing well. You can see the versions of the PN7150 in section 6 of the Data Sheet.
You can buy the C11006 directly in our page, or if you are interested in the C11002 version, you can buy it to one of our distributors. One important remark, is the IC packing method. (E: TRAY, Y: REEL).
The recommendation would be to use the version C11006, as it includes the new features and fixes mentioned in the Data Sheet.
Hope this helps.
Ricardo
zhichaotan
hi,if the pn7150 hardware switch to c11006 from c11002, it is there anything need to modify in the Android lower driver? Or can it be replaced directly?
