NFC NXP library
NFC NXP library
4,118 次查看
deepanrajanbara
Hi ,
We currently using NFC library provided by NXP.We just wanted to know that the library supports MIFARE desfire card or is there any other library available for supporting Mifare desfire.
Please reply as soon as possible.
Thank you,
Deepanraj.A
6 回复数
2,857 次查看
deepanrajanbara
Yes it supports Desfire cards. Please refer the below link
https://community.nxp.com/thread/435636
Thank you,
Deepanraj
2,857 次查看
weidong_sun
Hello Deepanraj.A,
      MIFARE desfire product is ours, of course, our library supports it!
Besides NFC Reader Library, we also provide patches for linux and android syste, you can get them from our official website.
Hope above information can help you!
Weidong Sun
2,857 次查看
deepanrajanbara
Hi Wigros Sun,
we are not able to find the link to the linux patch files.Can you please share me the link.We wanted to make Ultralite card read and write in our NFC module ( in iMx6 platform).
We are referring AN11697 PN71x0 Linux Software Stack Integration Guidelines for building Library, Driver and Using the same demo app to test NFC read and write
2,857 次查看
diegovalladolid
Hello deepanrajanbarasan,
Did you get the links that @Wigros mentioned? If not, how did you solve your problem communicating with MIFARE DESFire through PN71xx (PN7120 in my case) an vía Linux?
Any help is highly appreciated.
Thank you in advance.
2,857 次查看
deepanrajanbara
Can you Please share me the path to this Linux and android patches.
In our case i am using library of NXP for reading and pollong nfc data but this only works in the case of Mifare classic card .In the case of Mifare desfire ev1 it is not able to read or write any data. from the demo app.This is the output am getting
Waiting for a Tag/Device...
        NFC Tag Found
                Type :          'Type A'
                NFCID1 :        '04 43 5C C9 92 26 80 '
                NDEF Content : NO
After this there is no reply.Please provide any solution on how to check data of desfire cards and ultralite cards.
Thank you,
Deepanraj.A
2,857 次查看
deepanrajanbara
Is there any setting to check desfire_ev1 which is to be enabled in NXP source code
Thank you,
Deepanraj.A
