MiFare DESFire Light Session key generation and CMAC algorithm
2,193件の閲覧回数
dev-support
Hi All,
I am using #MIFARE DESFire Light for one of my customer. I can successfully authenticate the card using DESFireEV2First algorithm. After that I'm trying to get the session keys (SesAuthENCKey/SesAuthMACKey) as explained in example of AN12343, Chapter 7.1.3.1/7.1.4, but I can not get the expected output for the session keys.
So, my concern is, Can I use same CMAC algorithm in DESFire Light which was worked in DESFire EV1?
If YES, output of CMAC algorithm used in DESFire EV1 = 8 bytes (MAC)
And we want output of CMAC algorithm in DESFire Light = 16 bytes Session keys (SesAuthENCKey/SesAuthMACKey).
it looks confusing for me.
Any guideline regards this will be highly appreciable!
タグ(1)
3 返答(返信)
2,021件の閲覧回数
dev-support
Hi Ivan,
Thanks for the response. The issue was with the XOR calculation. Now, I can get the correct Session keys from the active DESFireEV2 first authentication of DESFire Light.
I’m facing issue in write data and read data after this.
1) When I try to WriteData in 00EF or 04EF, it gives me error 0x7E (LENGTH_ERROR).
I can successfully write data "22222222222222222222222222222222222222222222222222" in encrypted mode same as example of AN12343 (section 8.1.3).
But if I try to write my data which is 16 bytes or less i.e. "3132333435", it gives me 0x7E error.
>> Write Procedure I followed:
IV_Input = A55AFBCF7BCF00000000000000000000 (lable + TI + CmdCounter + Padding followed by 00)
SesAuthENCKey = 1D8C929597A19990295306DEFC57755A
IV = 00000000000000000000000000000000
IV_For Command Data = 6034C0FA74F032CBFFED3B6F3E9C584A
Data with Padding = 31323334358000000000000000000000
Encrypted Data = 77A2FD1B2BC19EC917B26D17694B6844
Command Header = 00000000050000
MAC_Input = 8D0000FBCF7BCF0000000005000077A2FD1B2BC19EC917B26D17694B6844
SesAuthMACKey = 2D9377F5CAAA1D53935454806B170723
Calculated MAC = CD3177470834C634
APDU to Card = 908D00001F0000000005000077A2FD1B2BC19EC917B26D17694B6844CD3177470834C63400
Response from Card = 917E (LENGTH_ERROR)
Can you guide me which one is the wrong step I'm followed.?
2) Also, I have followed below steps to read data 22222222222222222222222222222222222222222222222222”,
but it gives me 0x1E (INTEGRITY_ERROR).
>> Read Procedure I followed:
Command Header = 00000000190000 (FileID = 00, offset = 000000, DataSizeToRead = 19 bytes)
MAC_Input  = AD0100B39DB01400000000190000
MACKey = C3D79B25473D4DC735F856F6DA8F7C22
Calculated MAC = E2B5F6406CF1FA8C
APDU to Card = 90AD00000F00000000190000E2B5F6406CF1FA8C00
Response from Card = 911E (INTEGRITY_ERROR)
Can you guide me which one is the wrong step in read data I'm followed.?
 NFC
2,021件の閲覧回数
wilmer_suarez
I'm currently working on generating the session keys for MIFARE DESFire Light. Is there a library you used to generate the CMAC algorithm? I've tried multiple solutions but I'm unable to generate the proper values.
Thank you!
2,021件の閲覧回数
IvanRuiz
A reply was already made to the case, the keys generated are incorrect, please follow AN12343 minutely.
BR,
Ivan.
