The main problem is that we can write the defective cards properly,seems that this cards are corrupted.
Our program know that there are a desfire card ,however it can not be possible to write in the card.
Reading the card state with the tag App ,found Authentication Error as below:
# Memory content:
Application ID 0x000000 (PICC)
* Key configuration:
- 1 (3)DES key
- Master key changeable
- Master key required for:
~ directory list access: no
~ create/delete files: no
- Configuration changeable
Application ID 0x5A454E
- Key configuration unavailable (Authentication Error)
* No file information (Authentication Error)
Hope you are doing well. Could you please share a complete screenshot of the TagInfo? (The "IC Info", "Extra" and "Full Scan " tabs).
With this screenshot we cannot say something.
Ricardo
