MFRC522/MFRC630 long cable antenna?
1,084件の閲覧回数
michelebertoni
Hi to all, I have this question: I need to use MFRC630 (or more common MFRC522), but not with integrated antenna.
On market I can find a lot of MFRC522/630 boards, but all with integrated antenna.
I need:
MFRC522/MFRC630 PCB ------>>--------- 5 meters cable ----------->>---------- antenna
Is there a way to do this?
I can find several types of antenna, but having +5V, RX, TX, GND or +Vant,-Vant pins, so I have no idea about connect antenna to MFRC522/MFRC630....
Thanks.
1,011件の閲覧回数
weidong_sun
Hello michelebertoni ,
     Unfortunately! 5-meter cable is too long, we don't have ready-made solution for you. But you can use single-ended antenna, which can bought from market, or ask provider to make a customized for you with coaxial cable,then test it on your NFC reader board.
    On single-end antenna application, I will send it to your personal email.
Have a nice day!
BR,
Weidong
