Is PN7362 a drop in replacement for PN7462 (as long as contact interface is not used)
s_ali
We have aproven and mature design basde on PN7462 but we are now facing the availablity issues of this chip. Is PN7362 a drop in replacement for it? (We don't use contact interface or any other IO interface)
danielchen
Hi @s_ali :
It is pin compatible. Please refer to datasheet for more details.
motog
If you are not using contact interface then you can use PN7362. Also refer datasheet for other details.
danielchen
Hi @s_ali :
