Intro to NTAG originality check
2,575件の閲覧回数
mortimer678
Which document best illustrates how to perform the originality check for an NTAG 213/215/216/424 in a native iOS or native Android app? (Or how to perform the originality check at all?)
I understand that it requires a public/private key too for which I already have Secure Access Rights but do not see where to find and/or generate the key(s).
Any help would be appreciated.
6 返答(返信)
2,539件の閲覧回数
KaiLi
Hello @mortimer678
Please check the following thread, there is an answer for how to originality check.
Demo for Originality Signature Verification - NXP Community
kelly
2,288件の閲覧回数
yosuf
This example mentioned does not use the curve secp224r1 which the NTAG 424 uses. Could you guide on how we can adapt the demo for the ECC secp224r1. Thanks
2,184件の閲覧回数
yosuf
@KaiLi Could you look into this please? Thanks
2,527件の閲覧回数
mortimer678
Thank you @KaiLi. How do we get the public key? It is unclear if this is something we're supposed to generate from the chip (like the document implies) or generate through the DocStore (like the thread I linked to in my reply above).
2,525件の閲覧回数
KaiLi
Hello @mortimer678
I'll create a new case for you, we'll continue this topic related security file.
So, this thread will be closed.
Kelly
2,549件の閲覧回数
mortimer678
@michaelneurohr you responded in the following thread that the key must be acquired through the DocStore. Can you please elaborate?
https://community.nxp.com/t5/NFC/public-key-for-ntag213-originality-check/td-p/617014
