Interfacing ATTINY85 and NTAG I2C plus (NT3H2111)
631 次查看
EthanMathew25
    How do I interface ATTINY85 and NTAG I2C Plus (NT3H2111) ? I have NDEF Formatted data in the microcontroller from there how do I interface it with the NTAG IC ? although since it is a SMD component how do I verify if it works properly or not ?
标记 (4)
2 回复数
614 次查看
Tomas_Parizek
Hello EthanMathew25,
You can e.g., order an NTAG I2C Plus dev. board and connect it with your ATTINY85 device.
https://www.nxp.com/products/rfid-nfc/nfc-hf/connected-nfc-tags/ntag-ic-plus-2k-nfc-forum-type-2-tag...
Tomas
604 次查看
EthanMathew25
Hello Tomas,
I'm aware about the development board present but I wanted to know how I can do it without the development board. Can you please provide any insights with regards to that ?
