I have using dynamic nfc IC NT32211. It's not working i2c communication in raspberry pi B . i have try pull resister 1k to 15k resister but not responce in i2c address.
Would you please probe the I2C interface and check if the timing meets the following?
Please note The READ and WRITE operation handle always 16 bytes to be read or written (one block ).
Hope that helps,
Kan
