I can't make PN7150 recognize card 2cm or more(between PN7150 and card).
1,780 次查看
馬場重人
I'm sorry my poor English. I'm Japanese.
2cm or less OK. but 2cm or more is NG.
Why I Can't?
If I need adjust settings, please teach me.
(RX_GAIN? or something else?)
Best regard.
标记 (4)
1,642 次查看
weidong_sun
Hello 馬場 重人,
   Generally speaking, the effective range is 1cm~3cm when NFC reader reading a Tag, so I feel 2cm should be OK.
In additon, probably using LDO should be better than DC-DC converter.
TIC  weidong
4 回复数
1,642 次查看
Jonathan_Iglesias
Dear 馬場 重人,
hope you are doing great, I would like to know if you are using our evaluation board or if you are using your custome  board.
Jonathan
1,642 次查看
馬場重人
Mr. Jonathan Iglesias
Thank you for your reply.
I have used PN7150 SBC KIT FOR RASPBERRY PI OM5578/PN7150RPI.
I had used DC-DC converter for 3.3V power, It is not good.
But I changed form DC-DC converter to low dropout voltage regulator for 3.3V, It is good.
DC-DC converter:TI TPS54331
low dropout voltage regulator:JRC NJM2830
Is Low dropout voltage regulator better than DC-DC converter to supply PN7150?
Best regard.
1,643 次查看
weidong_sun
Hello 馬場 重人,
TIC  weidong
1,642 次查看
馬場重人
Mr. Wigros Sun
I will use that as reference from now on.
