Hello @DavidCL97
Not sure what your formatting behavior is, NTAG 424 DNA does not have format command.
reads and writes NTAG 424 DNA action can be protected by accessing rights. The application of the NTAG 424 DNA includes 5 AES 128-bit keys with key numbers 0, 1, 2, 3, 4. Furthermore, key number "E" (means free).If you want to read only, then readAccessKey = 0E, and writeAccessKey could be 0,1,2,3 or 4. For the details, check relevant sections of the datasheet please.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002qXhrcAAC
The portal allows access to the full details of the case, including the previous communication.
Kelly
Technical Support
NXP Semiconductor
