How to use RFID DiscoverLite or NFC Cockpit to read from NTAG213?
987 次查看
thederek
Hello, I'm trying to read the data in an NTAG213. I have the PN7462C development kit. How do I do this?
When I try with the RFIDDiscover Lite, I get an error "unable to find an entry point named phhalHw_DUT_Init in DLL NxpRdLib.dll"
Derek
1 回复
968 次查看
Fabian_R
Hello, my name is Fabian, I've been assigned to support your case.
I appreciate your interest in our products.
Could you please tell me what are you trying to achieve after reading the Tag? I'm asking this because both applications work for different purposes.
RFIDDiscover is intended to configure the tag according to your project requirements.
NFC Cockpit is intended to configure the reader registers and fine-tune the antenna performance.
In case you are looking for an application, my recommendation is to please use NFC Reader Library with MCUXpresso.
Fabian
