How to use LRP for NTAG424?
2512903047
90 71 00 00 08 01 06 00 00 00 00 00 00 00
return 91 9d
90 71 00 00 01 01 00
return 91 7e
And ... In AN12321
PCDResponse= 89B59DCEDC31A3D3F38EF8D4810B3B4 (15.5Bytes???!!)
If possible, try to give a detailed example, otherwise I don't know which step is wrong
Tags (3)
Jonathan_Iglesias
Hi ,
Hope you are doing great, in this case the best would be that you use our application note dedicated to LRP, this is not deditated to a certain product, it explaind how LRP is implemented and the steps to befollowed in order to  correctly calculate the encrypted/decrypted data
https://www.nxp.com/docs/en/application-note/AN12304.pdf
please check the link above and follow the procedure explained there.
Have a great day !
Jonathan
