How to PN7150 Re-Discovery without removing NFC tag
griffith_chen
We have example code from PN7150_SW4325/NXPNCI-K64F_Example (Work perfectly)
Currently, we have one requirement, the NFC tag cannot remove from PN7150's field, but we want to let PN7150 can find this NFC tag again (we want to PN7150 could find NFC tag every 5 seconds, even the NFC tag has found before) and we have no idea how to do this even we try to following procedure, the NFC tag cannot be found again, any suggestion to guide us? Thank you so much.
NxpNci_StopDiscovery();
NxpNci_StartDiscovery(DiscoveryTechnologies,sizeof(DiscoveryTechnologies));
nxf58474
Hope you are doing well. The NXP-NCI example aims to detect the tag only once and wait for the tag to be removed. And then the Discovery Loop begins again.
In NXPNCI-K64F_example>source>nfctask.c>task_nfc_reader, there is this function: NxpNci_ProcessReaderMode(RfIntf, PRESENCE_CHECK);
If you comment this function, and add a sleep of 5 seconds, it would meet your requirement:
You will be discovering the tag every 5 seconds, with the tag in the same physical location.
Hope this helps.
Ricardo
